1080i signal to 1080p HDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 05-06-2012, 09:39 PM - Thread Starter
petriebird's Avatar
I just built a new computer with hdmi and hooked it up to my new denon 1712.
For some reason I have to use a 1080i signal on my TV to get the scaling correct, otherwise at 1080p my control center removes the scaling option and everything is to big for my screen.
My question is, will I cause any damage to my HDTV because it's 1080p?
petriebird is offline
post #2 of 16 Old 05-06-2012, 10:35 PM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
No
RollTide2011 is offline
post #3 of 16 Old 05-07-2012, 08:26 AM
sitlet's Avatar
No problem. No different than connecting a 1080i cable box.
sitlet is offline
post #4 of 16 Old 05-14-2012, 06:53 AM
jharrison.mfsr's Avatar
Like everyone else is saying, nope. You could send it 480 and the TV wouldnt care at all.
jharrison.mfsr is offline
post #5 of 16 Old 05-14-2012, 12:02 PM
PlasmaPZ80U's Avatar
Quoted: 2194 Post(s)
Liked: 659
you cannot cause damage this way, even if you sent a resolution the TV doesn't support you just get a "not supported mode" message
a 1080p can handle 480i/p, 720p, and 1080i/p
a 720p can handle all of those formats aside from 1080p
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #6 of 16 Old 05-14-2012, 12:34 PM
indio22's Avatar
Quoted: 21 Post(s)
Liked: 46
But why then is he having problems with the 1080p signal from his HTPC? I am fairly sure my HTPC is outputting 1080p through my Denon 1712 receiver into my TV - and there is no problem handling it. I don't have the scaling issue as reported.
indio22 is offline
post #7 of 16 Old 05-14-2012, 01:13 PM
mdavej's Avatar
Quoted: 2212 Post(s)
Liked: 969
If "everything is too big" for the screen, then the TV itself needs to be set to 1:1 or native mode to get rid of overscan. Yours is set correctly, the OP's is not.
mdavej is online now
post #8 of 16 Old 05-14-2012, 06:38 PM
indio22's Avatar
Quoted: 21 Post(s)
Liked: 46
Good point - I do have my TV set to the "just scan" option that is suppose to display 1:1 mapping. Also, I don't recall having any issues with my i3 on-chip graphics, but some dedicated video cards might require playing with settings to eliminate overscan.
indio22 is offline
post #9 of 16 Old 05-15-2012, 12:16 PM
TheDude00's Avatar
No.
TheDude00 is offline
post #10 of 16 Old 05-15-2012, 01:50 PM
Selden Ball's Avatar
Quoted: 3356 Post(s)
Liked: 1637
Overscan adjustments (backporch timing, etc) are needed only for analog video signals unless you have a very poorly designed HD TV.
As an example, I have a Vizio 24" 1080p TV. When I connected my 1080p FHD laptop to it using VGA, there was a slight overscan. Just enough of the Windows desktop was missing around all four edges to be annoying. When I switched to displayport/HDMI, it became pixel-perfect. Now there is no overscan at all and I can see the entire desktop. It fits exactly within the TV's bezels. Although I previously had the impression that the VGA display was excellent, the computer's graphics now are noticably sharper since the pixels sent from the computer exactly match the pixels on the screen.
Edited to add:
Just to clarify: VGA signals are analog, although you probably were aware of that. My laptop's HDMI connection is getting to the TV by going through a Marantz nr1501 receiver, providing very good 5.0 surround sound. (I happen not to have a subwoofer in that room. It would have been too inconvenient due to space limitations. There's one on the system in the living room, though.)
Selden
Selden Ball is offline
post #11 of 16 Old 05-16-2012, 07:15 AM
mdavej's Avatar
Liked: 969
Like analog Component, VGA is also pixel perfect. Had you adjusted overscan, there would have been practically no difference between HDMI and VGA.
post #12 of 16 Old 05-16-2012, 07:58 AM
Liked: 1637
Sorry, but you seem to be using a different meaning for "pixel perfect" than I am.
Analog video signals are too easily "smeared". The timing of the sampling by the display device's input ADCs does not necessarily match the timing of the signal generated by the originating device. Too often, careful tweaking of sync signals, in addition to cable lengths and their dispersion indexes are needed to make sending and receiving devices agree. (e.g. sending VGA over Cat6 cabling is a pain since the pairs have different wraps and thus different frequency responses.) This is especially true for component (YPrPb/YUV) video, since normally its color difference signals have only half the resolution of its luminance signal.
In contrast, a digital video signal contains an explicit specification for each of the pixels that it transmits. There's never any question about what values have been assigned to which pixel. Unless, of course, there have been errors in the digital transmission. (How those pixel values get scaled onto a display device which has a digital resolution different from that of the signal is yet another problem, of course.)
Selden
post #13 of 16 Old 05-16-2012, 01:11 PM
mdavej's Avatar
Liked: 969
I agree analog can degrade over longer cable runs. But for short runs you'd be hard pressed to see any difference. VGA can also handle higher resolutions than HDMI (not that any TV's can take advantage of it). If you can use HDMI, it's always perfect, so use it by all means. But if you must use VGA, then you'll still get excellent results at reasonable distances.
post #14 of 16 Old 05-16-2012, 02:23 PM
Liked: 659
If you've seen CNET's results with PC-inputs via VGA, you'll see some TVs can give excellent PQ and resolution via VGA and others appear softer and may not show full resolution despite being set to 1080p.
http://reviews.cnet.com/flat-panel-t...wBody;continue
"PC: While it handled the full 1,920x1,080 resolution via its VGA input, the LND550 wasn't as good as the LG or Vizio in this department. We detected minor interference and softness in high-res test patterns--imperfect, but still better than the Sony overall.
Test, Result, Score
PC input resolution (VGA), 1920x1080, Poor"
post #15 of 16 Old 05-17-2012, 08:46 PM - Thread Starter
petriebird's Avatar
Originally Posted by RollTide2011 View Post
No
Thank you
post #16 of 16 Old 05-17-2012, 08:47 PM - Thread Starter
petriebird's Avatar
ummm.........
http://translate.google.com/
The link didn't help any.
Reply LCD Flat Panel Displays
