Question about Panasonic L32C5 and IPS panel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-07-2012, 10:01 PM - Thread Starter
JmarshallR's Avatar
Hi guys, this is my first post, so hopefully you will bear with me. Im looking at buying a 32 inch Tv for the bedroom, and the Panasonic L32C5 ($299) caught my eye. I haven't been able to find out much about this specific model, but the L32C3 with very similar specs seems to have an IPS Alpha panel. Does anyone know if the C5 has the same panel? Is this a worthwhile purchase as far as budget 32 inchers go? Thanks in advance.
JmarshallR is offline
post #2 of 6 Old 05-08-2012, 11:13 AM
Steve S's Avatar
Liked: 46
The 32" C5 is outsourced and does not have an IPS panel as did the C3.
Steve S.
Steve S is offline
post #3 of 6 Old 05-08-2012, 02:30 PM - Thread Starter
JmarshallR's Avatar
Thanks for the info. I'm not sure it really even matters when buying a budget 32" TV, but I just don't want to buy garbage. It has been a few years since I have looked at TVs, and it seems that every 32" available to me is made with not very high quality components. Is there a consensus on which manufacturers low model TVs use the highest quality components? Or at this price point is it all pretty much the same and its a personal preference thing.
post #4 of 6 Old 05-08-2012, 03:10 PM
fatuglyguy's Avatar
Quoted: 283 Post(s)
Liked: 610
the C5 has a slightly bigger/uglier bezel than the C3, definitely does NOT use an IPS panel (it has typical lcd viewing angles), drops the SD card slot, and replaces the digital optical audio out found on all Panny sets with a digital coaxial. To get a "real" Panny set, you need to step up to the X5.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
post #5 of 6 Old 05-08-2012, 11:09 PM
InYourEyes's Avatar
The Panasonic TC-L32C5, ans well as the TC-L42U5, is made by Compal for Panasonic, with panel screens made by Chi-Mei. I saw this TV in person, and the picture-quality is garbage-looking. Colors are weak and washed out, speaker quality is inferior, and power supply is small and cheap-looking.
Toshiba 32C120U is also made by Compal, and it sells for less than Panasonic. It uses a AU Optronics panel screen, which has a better picture quality than Chi-Mei. Last year, Consumer Reports rated the 32C110U the highest in picture quality for low-end 32" size.
InYourEyes is offline
post #6 of 6 Old 05-10-2012, 12:11 AM - Thread Starter
JmarshallR's Avatar
Thanks for the info. So after looking around some more, I found a 32" Toshiba 32SL410U LED for $294. Would the same info you gave me about the 120U apply to this TV? I also found a Panasonic C3 with the IPS panel for $349. Which of these would be a better TV?
Reply LCD Flat Panel Displays
Panasonic Viera Tc L32c5 32 Inch 720p Lcd Tv
