Anyone upgrade from a samsung LNXXA650 to 2012 LED? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-08-2012, 03:10 PM - Thread Starter
nickanderson's Avatar
Hello,
I currently have a samsung LN52A650 that has a vertical line out, and I was thinking of upgrading to the new samsung UNxxES8000 series. But I can not tell if the jump would be worth the cost ($2500+). I realize the specs have a huge jump.
Has anyone made this kind of jump, and if so was the picture quality difference dramatic?
thank you!
nickanderson is offline
post #2 of 3 Old 05-08-2012, 04:29 PM
lb750's Avatar
I made the jump fron the LN46A750 to the UN55ES7500. I still need to calibrate the picture, but it does have a better picture. I had the same problem as you but I had the BB warranty. They gave me a $1199 credit towards another TV. Well worth it!
lb750 is offline
post #3 of 3 Old 05-08-2012, 06:23 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Just go with the LN46A850 refurb for just under $800 from BB online site. The picture is still better than any new set ive seen in terms of color/refresh rate.
jaeelarr is offline
Reply LCD Flat Panel Displays
