Official Samsung UNxxES7500 thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 459 Old 12-29-2016, 08:10 PM
svtfast's Avatar
Quoted: 12 Post(s)
Originally Posted by rockstang View Post
I had not.
I found a place that has the SMPS for $85 and is in my state although it is a 6 hour drive to the store that has it.
Newbie to all of this.
svtfast is offline
post #452 of 459 Old 01-10-2017, 05:52 AM
BMWBig6's Avatar
Originally Posted by svtfast View Post
I only bought the cable......its 2.5 hours from me but UPS says 3 more business days.
I looked over the board. I am pretty good with circuits and circuit cards. I did not see any vent caps, burn marks, bad solder connections, etc.
So did just the ribbon cable (Samsung BN39-01475H Lead Cable) work in your case? (The power supply itself and the board didn't need to be replaced too?)
BMWBig6 is offline
post #453 of 459 Old 01-10-2017, 06:43 AM
svtfast's Avatar
Quoted: 12 Post(s)
It did. So far so good.
svtfast is offline
post #454 of 459 Old 01-11-2017, 05:06 AM
BMWBig6's Avatar
Thank you! I'm attempting the same repair, and will report back my results as another data point.
BMWBig6 is offline
post #455 of 459 Old 01-16-2017, 12:51 PM
BMWBig6's Avatar
Just to close the loop for others monitoring this thread, I replaced only the cable and it seems to have fixed my problem (so far). Thank you for the very helpful information--this thread is a great resource!
BMWBig6 is offline
post #456 of 459 Unread 02-13-2017, 02:31 PM
sma425's Avatar
Liked: 0
I found the cable and tcon board new online for about $85 US. I replaced the both and it is working great!!!
Can you tell me where you found the t-con board? I have the UN40ES7500 and the same problem with vertical lines and shutting off and on repeatedly. With the help of ShopJimmy, I identified the t-con part number on my tv as BN97-06372C0758. They don't carry that part and my Internet searches for that number turn up zilch. I wonder if there's an OEM part that matches but has a different number? Thank you!
sma425 is offline
post #457 of 459 Unread 02-13-2017, 02:54 PM
sma425's Avatar
Liked: 0
Originally Posted by fatmike View Post
The issue I have is that I bought my set from Woot, I know, I know, too good to be true and I should have known better. It turns out my model - UN40ES7500 was meant for the Latin American market and Samsung US couldn't even track the number down.
Did you ever get your tv fixed? I have the same model from Woot and am experiencing the colored vertical lines. I'm running into a dead end everywhere I try to find parts. I really want to fix this tv as it's really a great one...when it works!
sma425 is offline
post #458 of 459 Unread Yesterday, 07:57 AM
rockstang's Avatar
I found mine on aliexpress... Hope this helps. FYI, this may mean your main board is burned out too. I got lucky, it was just my t-conn.
rockstang is offline
post #459 of 459 Unread Yesterday, 08:07 AM
rockstang's Avatar
I think this is it. Just verify this is the right one for your model.
https://www.aliexpress.com/item/BN41...d-b5fc448ec47b
Reply LCD Flat Panel Displays
Samsung Un60es7500 60 Inch 3d Slim Led Hdtv , Samsung Un65es8000 Led Hdtv , Disney Wow World Of Wonder Blu Ray , Avatar 3d Blu Ray Collectors Edition
