Samsung LN40E550 Clouding issues? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-24-2012, 07:20 AM - Thread Starter
boswd's Avatar
Hi everyone, Last night I came home from Best Buy with the Samsung LN40E550. Overall my impression is a fairly positive one. colors are vibrant and pop without blooming, blacks are solid, not blackest but solid. Off angle , meh, could be better but I've seen worst, it's not it's strong point but not a deal breaker either.
The biggest concern was this unit suffers from horrible clouding, well actually only one cloud but it's a good sized one and located in the worst place possible. Dead center. it's unnotiicable during normal scenes etc and does very little to affect the picture. But any dark scenes it sticks out like a sore thumb. Trying to watch something Harry Potter would be unwatchable. when viewing dead center it's not all that noticalbe, but any slight off angle and it's clearly seen. I'm not talking way off to the side, but just the slightest off center viewing.
This unfortunatly is a deal breaker.
lowering the backlight to just 1 or 0 did get rid of it, but the picture is just way too dim at that point and not enjoyable.
So on Saturday I'm heading back to replace it. I was wondering if anyone else has any experience with this unit. I would like to just do an even swap out, because I do like the picture alot and it's a great deal. I'm just hoping it's only a lemon. so has anyone else have any experience with this model and have you had any clouding issues? or Any advice on handling clouding would be great as well.
Thanks in advance.
boswd is offline
post #2 of 6 Old 05-29-2012, 07:37 AM - Thread Starter
boswd's Avatar
****Update**** For anyone who is interested in this TV I did take it back over the weekend. And swapped it out for the same model. Happy to report, not the slighest hint of any sort of clouding whatsoever.
Just had a lemon. This is a great value, it is Samsung's budget line but an insane price for it. It's a bit of a beast to calibrate though. the "Standard" picture mode leans heavy on the cool, side. Primary colors and whites just POP and look gorgous but skin tons and secondary colors and flesh tone's look slightly washed out, with a slight tinge of ice blue, not horrible but just enough where you think somethig is just a miss. .
Using Movie mode and color temp of WarmII (warm I does nothing) takes care of the secondary colors and flesh tones and definitly adds to color depth and blacks are deeper. but like all Warm settings it does hurt the whites but not too horrible but I do like my whites to POP and they do under the "standard" picture mode, so it's a slight trade off.
Primary colors still look great. HDMI Black level should be left on normal. "Low " crushes the blacks.
Overall very happy especially with the size to price For most people the above won't even be a problem.
hope this helps anyone interested in it.
*** also mods can you please change the title to just Samsung LE550 since there is no clouding issues, I just got a bad one. thanks in advance. ******
boswd is offline
post #3 of 6 Old 06-10-2012, 09:35 PM
Bocatrip's Avatar
I just purchased the LN40E550 yesterday at bestbuy and I agree that the price is incredible. I'm not real savy with picture quality, but I also own a LN40D550 which has an incredible picture but was considerably more money. I don't have the LN40E hooked up to a comcast box yet, so I am not able to comment further on the picture quality. Again, where can you buy a Samsung 1080P 40" for that kind of money?
Bocatrip is offline
post #4 of 6 Old 02-10-2013, 10:52 AM
tycomps's Avatar
I have mine connected to my htpc via hdmi. Great deal but two issues:
1. Video tearing at times in fast motion areas of picture (looking into pc power supply on this)
2. Using as a monitor when it switches from an image to a white background the image remains momentarily until it fades away (takes about a second), this is also noticeable when scrolling the screen image. I was unable to find the response time spec for this (or any other) unit prior to purchase.
Anybody able to shed any light on the above?
Also could you please post your picture calibration settings, thank you.
tycomps is offline
post #5 of 6 Old 02-10-2013, 05:28 PM
biznus97's Avatar
Don't have those problems but make sure you go into the menu and set the Label for the HDMI to PC or DVI-PC. Mine is only connected to an HTPC.
biznus97 is offline
post #6 of 6 Old 02-19-2013, 08:45 AM
tycomps's Avatar
update: found out from Samsung that the response time on this model is 5ms. Switched to Blue Runner 15 foot HDMI 1.4 cable and set input tp PC, appears better, will post calibration settings when complete.
tycomps is offline
Reply LCD Flat Panel Displays
Samsung Ln40e550 40 Inch 1080p 60 Hz Lcd Hdtv
