No sound from HDMI connection to Bravia 46NX810 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-28-2012, 10:47 AM - Thread Starter
swhockey84's Avatar
Hi,
I have a Bravia 46NX810. I am connecting my PC to it via HDMI and using a male-to-male audio cable for sound. I have the HDMI connection in HDMI 2 under the "PC input" section of the TV and also plugged in the male-to-male audio cable in the same section area.
I am getting perfect picture, but no sound. I do not have a receiver, I plan on playing the sound through my Bravia speakers. My computer has an Essence ST audio card.
I would appreciate any help, it's driving me nuts. Thanks!
swhockey84 is offline
post #2 of 5 Old 05-28-2012, 11:21 AM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
My Sony has an 1/8" stereo jack for PC audio input. Sounds like yours is connected to the TV's output, not input.
Also you'll have to disable your PC's digital output in order for the analog output to work.
mdavej is offline
post #3 of 5 Old 05-28-2012, 12:35 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Isn't HDMI a video/audio connection? Why u have to use a separate audio connection is odd.
MrBobb is offline
post #4 of 5 Old 05-28-2012, 02:34 PM
mdavej's Avatar
Liked: 940
HDMI from many PCs carry only video due to source being DVI. I personally use coax/optical straight to my AVR so I get DD 5.1 at least.
mdavej is offline
post #5 of 5 Old 05-28-2012, 04:24 PM
walford's Avatar
I had to make a setting change on my PC to tell it to also output audio over it's HDMI connection.
walford is offline
Reply LCD Flat Panel Displays
