Best led 55 inch to buy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-28-2012, 01:27 PM - Thread Starter
esj
esj's Avatar
what 55 inch led unit would you purchase within the 1200-1400 range,picture,realibity wise,must be black,3D is not a must,120 or 240 is fine,a high rated lcd may be ok if its priced right but prefer led
esj is offline
post #2 of 2 Old 05-28-2012, 08:38 PM
gosugadget's Avatar
1200-1400 dollars/pounds/euros? Please clarify.
LG LM series are great passive sets with a good/fast smart TV interface. Remote is a plus as well.
Sony HX850, the reviews say its a good performer (active set)
Panasonic ?T50, the LED they have had good black levels.
If you wanna go cheapest without sacrificing too much performance, I recommend the LG LM series.
gosugadget is offline
Reply LCD Flat Panel Displays
