Anyway to get a Philips Aurea to work in US? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-03-2012, 05:10 AM - Thread Starter
dropgems's Avatar
I've wanted this TV forever. I have an older Philips ambilight and im disappointed that they don't make ambilights in the US anymore. Has anyone ever gotten an Aurea to work in the US? Thx.
dropgems is offline
post #2 of 7 Old 06-04-2012, 04:08 PM - Thread Starter
dropgems's Avatar
Bump
dropgems is offline
post #3 of 7 Old 06-24-2012, 02:23 PM
da1stprince's Avatar
bump again... i am very intersted in getting one to replace my old ambilight 42" model
da1stprince is offline
post #4 of 7 Old 06-26-2012, 04:17 AM
wazymk's Avatar
As far as I know you would require a step up transformer to take your line voltage from 120 v up to 220 volt - have a look on the internet and there is a number of solutions available to do this. You will also require a special 2 prong adapter to convert the line cord over to the north american style plug - these are available on e-bay or radio shack - I imported a Philips reel to reel tape recorder from Berlin last year and bought a 2 prong AC adapter on e-bay - Fortunately, the recorder had a switch on the back to enable it to be switched from 220 volt down to 120 volt. ( i highly doubt the Aurea would have this ) Look on line for 120 volt to 220 volt ac converters and you should be able to find both the transformer and the 2 prong adapters.
Hope this helps
Wazy
wazymk is offline
post #5 of 7 Old 06-26-2012, 08:47 AM
Steve S's Avatar
Liked: 46
Have you considered simulating "ambilight" with a simple bias light behind a US spec set?
Steve S.
Steve S is offline
post #6 of 7 Old 02-11-2013, 12:40 AM
PhilipsPhanatic's Avatar
Quoted: 398 Post(s)
Liked: 52
Anybody in the U.S. have a UK Philips Aurea set that works ? Would LOVE to get one of their high-end (but dated) models with the Ambilighting Aurea if possible.
PhilipsPhanatic is offline
post #7 of 7 Old 08-18-2014, 02:42 AM
Quoted: 398 Post(s)
Liked: 52
Originally Posted by wazymk View Post
As far as I know you would require a step up transformer to take your line voltage from 120 v up to 220 volt - have a look on the internet and there is a number of solutions available to do this. You will also require a special 2 prong adapter to convert the line cord over to the north american style plug - these are available on e-bay or radio shack - I imported a Philips reel to reel tape recorder from Berlin last year and bought a 2 prong AC adapter on e-bay - Fortunately, the recorder had a switch on the back to enable it to be switched from 220 volt down to 120 volt. ( i highly doubt the Aurea would have this ) Look on line for 120 volt to 220 volt ac converters and you should be able to find both the transformer and the 2 prong adapters. Hope this helpsWazy
But what about the different electronic and chip parts, NTSC, etc.
Voltage aside, would the TV work on U.S. cable systems ?
Reply LCD Flat Panel Displays
