If i dont get a plasma what Lcd should i get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-03-2012, 01:37 PM - Thread Starter
Barana2080's Avatar
I am about 89 percent sure I will get a Panasonic St50 plasma. If I decide to go with LCD what brand is comparable to this tv in price and quality? Looking at 50 incher.
Barana2080 is online now
post #2 of 14 Old 06-03-2012, 11:49 PM
beat_strandh's Avatar
Sony HX850 46" or 55"
check cnet and AVF reviews.
beat_strandh is offline
post #3 of 14 Old 06-04-2012, 04:22 AM
8mile13's Avatar
Quoted: 1703 Post(s)
Liked: 989
The 55HX8500 is $2.500, the 55ST50 $1.500 so there is a $1.000 price difference. The HX8500 is a Edge Lit, if you want plasma kind of blacks you should go Local Dimming $$$$. Best TV first half 2012 is the VT50, one could wait till the price drops
LEDs compared: Local Dimming, Edge Lit
http://reviews.cnet.com/2795-6482_7-399.html
8mile13 is offline
post #4 of 14 Old 06-04-2012, 07:03 AM
Phase700B's Avatar
Liked: 25
The Samsung 55EH6000 or EH5000 TVs are FULL array LED back lighted TVs and have gotten very good/mixed reviews. The key is to get any TV from a store that handles and stores them properly. Much of the flashlighting issues for instance can be attributed to the TV not being stored upright or manhandled. Anyway, the EH5000/EH6000 are pretty impressive for their price range and I was impressed in store viewing.
At least something to consider. Good, basic TVs with a potential for excellent picture quality. Buy a Blu-ray or streaming box for your web interests. Upgrade is cheaper by doing so and usually more feature rich than having apps on a TV.
__________________
Phase700B is offline
post #5 of 14 Old 06-04-2012, 10:05 AM
8mile13's Avatar
Liked: 989
Samsung does not make Full Array LEDs anymore, last one was the 2009 B8500.
8mile13 is offline
post #6 of 14 Old 06-04-2012, 10:49 AM
Phase700B's Avatar
Liked: 25
I thought so too. . . guess what? Actually they ARE back lighted Full Array LED. Apologies accepted.
The updated information on the EH4000/EH5300/ EH5000/EH6000 state they an entry level Full Array LED TV with minimum features but very good picture quality. Samsung apparently is doing this as a way to move away from CCFL LCD panels. They essentially took CCFL models and converted them to a limited Full array LED back light system. I looked at several of these in stores and they look pretty darn good. . . and
use a limited number of LEDs , but are impressive non the less. Especially for the $$$.
Here's a link to CNET 2012 TV models. Check the Samsung tables on the chart.
http://reviews.cnet.com/8301-33199_7...hdtv-compared/
post #7 of 14 Old 06-04-2012, 01:57 PM
8mile13's Avatar
Liked: 989
^^ thats a surprise!
8mile13 is offline
post #8 of 14 Old 06-04-2012, 02:01 PM
Phase700B's Avatar
Liked: 25
Yes, it was for me also. There is a thread here started on the EH6000/EH5000. Kind of mixed reviews, but the ones I saw in the 47" size for UNDER 1K made me want to try one just to play with.
post #9 of 14 Old 06-04-2012, 04:55 PM
caeguy's Avatar
They are Full Array LED TV but no local dimming.
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
post #10 of 14 Old 06-04-2012, 05:04 PM
PlasmaPZ80U's Avatar
Quoted: 2235 Post(s)
Liked: 684
Unfortunately, the number of LEDs is limited... so uniformity is still not ideal, though it is a significant improvement over the ES models (edge-lit LED).
FWIW, this is definitely a step in the right direction for Samsung. Hopefully, they can lose the 'title' of least uniform LED-LCD screens in time.
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #11 of 14 Old 06-04-2012, 09:34 PM
getbigg21's Avatar
Quoted: 91 Post(s)
Isn't the eh5000 only 60hz compared to 120hz on the eh6000?
getbigg21 is offline
post #12 of 14 Old 06-04-2012, 10:02 PM
Liked: 684
I wasn't talking about refresh rates.
post #13 of 14 Old 06-04-2012, 11:55 PM
aah sorry. Im from Sweden and here the 55HX850 is $2.900 and the 55ST50 is $2.640
post #14 of 14 Old 06-05-2012, 05:14 AM
8mile13's Avatar
Liked: 989
CNET
55HX850 $2.600
http://reviews.cnet.com/flat-panel-t...-35118056.html
55ST50 $1.600
http://reviews.cnet.com/flat-panel-t...-35118300.html
i live in Holland,
55HX850: 1.999 - 2.379
http://www.kieskeurig.nl/led_tv/sony...35588/#prijzen
55ST50: 1.659 - 1.986
http://www.kieskeurig.nl/zoeken/index.html?q=55st50
8mile13 is offline
Reply LCD Flat Panel Displays
