Motion problem with Samsung 40EH5000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 06-08-2012, 01:12 AM - Thread Starter
Richdot's Avatar
I am currently having a problem with my new samsung EH5000. The screen is very impressive but there is one problem I am having MOTION BLUR frown.gif on fast moving scenes and also playing on the xbox 360 playing FPS games and fifa 12. Is there a setting I am missing that can help reduce or completely clear this poor handling of motion?
Richdot is offline
post #2 of 44 Old 06-08-2012, 08:09 AM
Lookn4Friendz's Avatar
I have this exact TV.... Just received it and I too am searching for the optimal settings. No one seems to be forward enough to share theirs, so I've been playing with other settings near the model...I like these..
http://forums.cnet.com/7723-19410_102-563930/best-settings-for-samsung-un40eh6000/?tag=contentBody;threadListing
Lookn4Friendz is offline
post #3 of 44 Old 06-08-2012, 09:24 AM - Thread Starter
Richdot's Avatar
Yeah there for the 6000 and I am asking if there is such a setting that works to clear the bad motion handling or if it's something I will have to live with not after picture settings dude
Richdot is offline
post #4 of 44 Old 06-08-2012, 09:45 AM
getbigg21's Avatar
Quoted: 91 Post(s)
well you got to remember that you have a 60hz tv. that was the main drawback of the eh5000 series. i saw this at costco for $589 for the un40eh5050, but i decided to get the 6000 series instead b/c of the 120hz.
getbigg21 is offline
post #5 of 44 Old 06-09-2012, 05:25 AM - Thread Starter
Richdot's Avatar
Should not really matter that it's 60hz could still control motion better
Richdot is offline
post #6 of 44 Old 06-11-2012, 09:24 AM - Thread Starter
Richdot's Avatar
Could anyone tell me if the Samsung UE40EH6030 will be any better handling motion than my current EH5000? As its terrible I see ghosting etc most of the time!
Richdot is offline
post #7 of 44 Old 06-11-2012, 11:16 AM
Scofield314's Avatar
What settings are you using?
Scofield314 is offline
post #8 of 44 Old 06-11-2012, 03:18 PM - Thread Starter
Richdot's Avatar
Game mode "on"
Picture mode " Standard "
Backlight " 6 "
Contrast " 85 "
Brightness " 45 "
Sharpness " 25 "
Colour " 50 "
Colour tone " Warm1 "
Everything like Dynamic contrast etc all OFF, all the mpeg noise filter etc all OFF also.
Richdot is offline
post #9 of 44 Old 06-11-2012, 03:35 PM
nitra's Avatar
Liked: 56
You know, turning on game mode removes all the TV's processing, this very well can be a contributing factor.
Unless you're playing a game that requires game mode, you really should disable it.
Posted settings for the ES8000 yesterday, along with detailed reasons.[=www.avsforum.com/t/1399319/official-samsung-unxxes8000-thread/1050#post_22115441][/]
nitra is offline
post #10 of 44 Old 06-11-2012, 03:53 PM - Thread Starter
Richdot's Avatar
So even though I am gaming on the xbox 360 I should turn " Game mode " off then?
I thought turning game mode on would help reduce the bad motion handling in games
Plus I also thought having Game mode on would reduce input lag?
Richdot is offline
post #11 of 44 Old 06-11-2012, 04:22 PM
nitra's Avatar
Liked: 56
It will only help input lag, but will make the picture look pretty terrible. You'll find most games won't require game mode. COD, and such, might, but only turn it on if you notice the lag.
nitra is offline
post #12 of 44 Old 06-11-2012, 04:43 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
what kind of LCD panel do you have? look for the panel version code on right side of TV (two letters followed by two digits) to find out
*VA panels in general have such issues (ghosting/blurring/smearing of dark areas especially)
not an issue with IPS panels, though, like those on LG and Panasonic LCDs
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #13 of 44 Old 06-11-2012, 05:59 PM - Thread Starter
Richdot's Avatar
it says version 01?
Richdot is offline
post #14 of 44 Old 06-11-2012, 06:33 PM
Liked: 560
it says version 01?
what is the full code (should be four characters)?
post #15 of 44 Old 06-11-2012, 07:14 PM - Thread Starter
Richdot's Avatar
UE40EH5000KXXU ? would that be it ?
Richdot is offline
post #16 of 44 Old 06-11-2012, 09:22 PM
Liked: 560
no, look for a sticker on the right side of the panel or back of the panel that has code like AA02, SQO1, SS02, etc
it should be labeled "version"
post #17 of 44 Old 06-12-2012, 06:48 AM - Thread Starter
Richdot's Avatar
on my label they must of changed it or something because my label is set out like this :
Model no: UE40EH5000KXXU
Version no: 01
S/N: 29dp3sjc301246a
Richdot is offline
post #18 of 44 Old 06-12-2012, 07:20 AM
bjfoien's Avatar
Have you updated your firmware to version 1012?
Samsung 46A750, Panasonic BD35, Dish 722
bjfoien is offline
post #19 of 44 Old 06-12-2012, 07:24 AM - Thread Starter
Richdot's Avatar
When I search for a firmware update via channel It says I am up to date but when I check on my version it says my current version is 001007???? is that the latest one?
Richdot is offline
post #20 of 44 Old 06-12-2012, 10:42 AM
Pandemonium08's Avatar
True, VA panels have this issue but so far I havent seen a scenario that is a deal breaker! Whats bothering me is the relatively low viewing angles on VA panels.. if you look at the TV in a mall your almost fooled into thinking that its viewing angle is like an IPS but its pretty close to TN. All in all im still very happy with the purchase as my primary PC monitor, hopefully LG releases something similar with an IPS panel+direct LED+full PC mode support and at a similar price range.. I would upgrade to that!
Pandemonium08 is offline
post #21 of 44 Old 06-12-2012, 11:35 AM - Thread Starter
Richdot's Avatar
Is the current version is 001007 ?
Richdot is offline
post #22 of 44 Old 06-12-2012, 12:17 PM
Liked: 560
the internet update feature doesn't always work so just download the file from the Samsung site to a USB drive and use that to update to the latest version
post #23 of 44 Old 06-12-2012, 12:21 PM - Thread Starter
Richdot's Avatar
I have tried to look for the firmware update from samsung site and I can't find it I have the 40" uk verison if that helps.
Has it fixed the motion blur or something?
Richdot is offline
post #24 of 44 Old 06-12-2012, 01:11 PM - Thread Starter
Richdot's Avatar
Right I am now updating to 1015 software, does anyone actually know what has been improved/changed? thanks
Richdot is offline
post #25 of 44 Old 06-12-2012, 05:16 PM - Thread Starter
Richdot's Avatar
Updated firmware issue is still there. I may just go back to my pc monitor seems I am very sensitive to stuff like this or its a problem with the tv frown.gif
Richdot is offline
post #26 of 44 Old 06-12-2012, 08:04 PM
Liked: 560
try another sample of your model if you can get a different panel version or just go for the 6000 series
post #27 of 44 Old 06-13-2012, 02:08 AM - Thread Starter
Richdot's Avatar
Not sure are the 6000 series motion blur free?
Richdot is offline
post #28 of 44 Old 06-13-2012, 10:28 AM
Liked: 560
it may not be blur free, but according to CR.org, it will show good motion performance (which is considerably better than the fair rating 60HZ sets get)
post #29 of 44 Old 06-13-2012, 03:55 PM - Thread Starter
Richdot's Avatar
I have decided to put up with it dude because everything is perfect apart from that
Richdot is offline
post #30 of 44 Old 06-19-2012, 02:18 PM
Elrowyn's Avatar
Version no: 01
I just looked at mine. It would have been where yours says "version". See mine says TS01. So right under model #, it juts says 01? There are no letters at all? If you are still within your return policy why not try the same set just a replacement? I mean mine has lag, not terribad but not good. Like when a head is moving around I see the shades of it as it moves. But it's not super noticable 100% of the time. If yours is not much worse than that, then I'd say it's about normal for this set.
Elrowyn is offline
Reply LCD Flat Panel Displays
Samsung 40 Inch Ua 40eh5000
