Official Samsung UNXXES7100 Thread. - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2431 of 2916 Old 03-31-2013, 04:18 PM
etp
etp's Avatar
Quoted: 17 Post(s)
Just hooked up my 46" and upgraded the FW and noticed a thin faint grey line on the extreme left, right, and bottom.
Any one else have this and does it need to go back to BB?
ETP
etp is offline
post #2432 of 2916 Old 03-31-2013, 05:01 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Originally Posted by tide_high View Post
Flash lighting right near the stand connection... Think it's from the stand pressure?
Tried the tape over the ir for interference shielding, no bueno
If the cloud near the stand is present when the tv is first powered On, then the stand iternal mounting screws may be the cause. Ifthe cloud near the stand shows up after viewing for a while then it may be related to heat buildup near that area as describd in the 8000 thread. When real bad, you may see a V shaped cloud centered at stand center. My 2 6500s I returned had the V cloud really bright and totally distracting to the eye after warm up.
mgh26 is offline
post #2433 of 2916 Old 03-31-2013, 06:29 PM
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
All the ultra-thin bezel 46 inches and 55 inches Samsungs have the thin faint grey line on the far left and right.
The ES7100, ES7500, ES8000, F7100 and F8000.
Don't know about the bottom though.
PiratesCove is offline
post #2434 of 2916 Old 03-31-2013, 06:31 PM
Quoted: 82 Post(s)
Liked: 176
+1, I've seen this in my two panels (its very faint), I think its heat and pressure related.
Allegedly its fixed in the F series.
post #2435 of 2916 Old 04-01-2013, 12:58 PM
droseofc's Avatar
Quoted: 12 Post(s)
What are some of the risks involved when having the panel replaced? I had a small inch sized section where bezel was loose and could see backlight shining through, repair guy came and said whole panel (screen) is going to be replaced. Not sure if it matters but currently it is US02. I just want to know if there's anything i should look for once they replace it.
droseofc is offline
post #2436 of 2916 Old 04-01-2013, 09:31 PM
tide_high's Avatar
Well ****... It is a V. So it's not going to improve? Should I return?
Thanks guys
tide_high is offline
post #2437 of 2916 Old 04-01-2013, 10:21 PM
nsievers's Avatar
anybody been getting a "error_model_bind" error message popup lately? I just started getting one tonight. Pops up every few minutes for a few seconds. Very annoying. First time I have seen it and the tv has been working fine for months. I try to resetup the network and it says everything is fine, but it will continue to popup. I read somewhere it has something to do with the smarthub possibly server related, but I am not even using the smart hub. Anybody seen this before?
nsievers is offline
post #2438 of 2916 Old 04-01-2013, 10:59 PM
dcontto's Avatar
Yes I noticed the same error message. I pretty sure it's the Smart Hub server as I tried to connect to apps and failed. I've seen that message before and eventually Samsung gets around fixing the server.
dcontto is offline
post #2439 of 2916 Old 04-01-2013, 11:04 PM
nsievers's Avatar
ok, atleast I am not the only one. Its just annoying as hell to have it pop up every couple of minutes. I mean ok great the servers are down, I get it, I am not using smart hub quit bugging me about not connecting during normal programming. jeez samsung.
nsievers is offline
post #2440 of 2916 Old 04-01-2013, 11:17 PM
delaAVS's Avatar
i was getting that error blind for awhile i think the maintance that is supposed to happen tonite or last night was supposed to address that issue i havent had that network blind in awhile it was happening for a few days and annoyed the **** out of me
delaAVS is offline
post #2441 of 2916 Old 04-01-2013, 11:31 PM
delaAVS's Avatar
just happened again but im trying to use the hub netflix not letting me connect guess they are working on it
delaAVS is offline
post #2442 of 2916 Old 04-02-2013, 12:53 AM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
I,m getting my US02 panel replaced tomorrow. I,ll let you know what risks there are based upon my experience. Sure hope all goes well since my current panel had excellent 2D.
mgh26 is offline
post #2443 of 2916 Old 04-02-2013, 05:13 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
OK now I have to say my new panel arrived damaged. BUT.... The tech didn't inspect it until he tore my entire TV apart first. What a WASTE of time. I am now in the parts on order status again and my TV is back togeather and working as before so all is not lost. I did have the tech avoid over tightening any screws and I believe my results are as good as before the tear down with no clouding or noticable flashlighting. The biggest risk I seemed to deal with was in waisting my time in trying to resolve the issue so far. I can live with that (for now at least). WAPITA though.
mgh26 is offline
post #2444 of 2916 Old 04-02-2013, 06:07 PM
axm438's Avatar
I had my TV ripped apart and put together three times before I was finally given an exchange for a brand new TV. Good luck trying to get a suitable panel. All three of my were always worse then the last. I have a feeling these replacement panels are not new but refurbished. The last panel they brought over looked like it had some decals and stickers removed and replaced. You could still see the left over glue from the decals.
axm438 is offline
post #2445 of 2916 Old 04-02-2013, 06:42 PM
tondo90210's Avatar
Originally Posted by PiratesCove View Post
Another reason I'm sticking with FW 1027..
Try pushing the Source button and then the red A (bottom right) button to refresh...or
To solve your ARC issue try a Factory Reset.
This link explains the process:
http://www.samsung.com/us/support/supportOwnersHowToGuidePopup.do?howto_guide_seq=6790&prd_ia_cd=N0000058&map_seq=44746
If you need the code its: 0 0 0 0
Wanted to post an update in case anyone else encounters the same issue. Issue is ARC was working fine until updating FW to 1029. (#UN60ES7150F from Costco Feb 2013)
Tried both types of re-set and did not solve the ARC problem with FW 1029.
Source button + RED reset caused the "Network not connected... Error model bind" to pop up intermittently even though the wi-fi is connected. Factory reset fixed this but not the ARC issue.
Reluctantly have to run a separate optical cable in lieu of the ARC.
tondo90210 is offline
post #2446 of 2916 Old 04-02-2013, 08:33 PM
Quoted: 82 Post(s)
Liked: 176
What a WASTE of time. I am now in the parts on order status again. The biggest risk I seemed to deal with was in waisting my time in trying to resolve the issue so far.
+1, Same thing going on here....I'm ready for the exchange.
post #2447 of 2916 Old 04-02-2013, 08:36 PM
Quoted: 82 Post(s)
Liked: 176
Originally Posted by axm438 View Post
Good luck trying to get a suitable panel. I have a feeling these replacement panels are not new but refurbished.
Samsung must like wasting their money and our time.
I also went through 3 panel fixes-all three in bad shape to finally get an exchange last year.
post #2448 of 2916 Old 04-02-2013, 09:41 PM
droseofc's Avatar
Quoted: 12 Post(s)
Awesomeness. So expect the worst and prepare for worse?
droseofc is offline
post #2449 of 2916 Old 04-04-2013, 03:01 PM
Quoted: 82 Post(s)
Liked: 176
If panel is cloud-free, flashlight-free, no dead pixels, no horizontal bands in 3D and other wise ideal...its a keeper.
Chances for that are slim, so on to the exchange and the F series.
post #2450 of 2916 Old 04-04-2013, 03:34 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Hope all goes as good as it can. I just did a self tracking on my issue since I had not received a new scheduled repair phone call and this is what I saw:
Ticket Number
current status transfering repair to exchange
service
requested date
repair
completed date
message
from samsung
Not very much info but now I am wondering what I'm going to end up with. I don't think a 46" F7100 is out there yet. Any idea how much time this process takes? I guess i'm Ok waiting since my current picture is cloud and flashlight free. Sure wish that darn dead pixel and the 3D horzontal banding wasn't there. I'm Ok with the TV otherwise.
mgh26 is offline
post #2451 of 2916 Old 04-04-2013, 05:42 PM
gunsmoker's Avatar
^^^ 46F7100 has been out for a while. The 60" showed up late to the party.
gunsmoker is offline
post #2452 of 2916 Old 04-04-2013, 06:49 PM
Quoted: 82 Post(s)
Liked: 176
Ticket Number
service
requested date
repair
completed date
message
from samsung
Sounds good, I hope the F7100 is an improvement.
I want to get the F8000, I like the design and Picture Quality is second to none.
I took around 3 weeks total for the approval and exchange last year.
post #2453 of 2916 Old 04-04-2013, 07:32 PM
gtang11's Avatar
I just picked up this TV a few weeks ago and so far love it. One issue or question at least. Should each picture mode have its own settings? I've noticed when changing color space settings in standard mode and then go into movie mode I see the changes. I just thought and had read each mode was independent. Any idea?
gtang11 is offline
post #2454 of 2916 Old 04-05-2013, 08:40 PM
Quoted: 82 Post(s)
Liked: 176
Wow...I believe Samsung actually found a better panel.
The 3D Horizontal Bands are gone....
The 2D picture quality and processing is better than the other 2 panels.
I still have the exchange option....
post #2455 of 2916 Old 04-05-2013, 08:46 PM
Quoted: 82 Post(s)
Liked: 176
The Custom Color space is shared per input-so changing in Standard effects Movie and vise-versa.
Color Space: Auto is more accurate in Standard.
post #2456 of 2916 Old 04-05-2013, 10:52 PM
pappaduke's Avatar
Quoted: 137 Post(s)
Liked: 133
Whenever I try to view 3D samples with smarthub, it does not play continuously and usually drops out completely. Obviously a network problem. With that being said, what are good/fast wireless routers out there that most are using? I'm no network expert, so please take it easy on me with the technical stuff. Thanks in advance for those that choose to reply.
Yamaha 2010
Oppo 103D,ATV3,PS3, Samsung UN60ES7100F, Bluesound Vault 2 and Pulse Mini, Harmony One, Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's. B&W P5
Zone2-Paradigm SE-1's, Zone3-Paradigm-Stylus 370-SM
pappaduke is offline
post #2457 of 2916 Old 04-06-2013, 03:01 AM
uclabruinn's Avatar
That's good news PC. Happy for you... I'm happy I got a good one from the get go. (Knock on wood)
uclabruinn is offline
post #2458 of 2916 Old 04-06-2013, 05:42 AM
gunsmoker's Avatar
I have had a Linksys wrt54g for over 4 years without issues.
post #2459 of 2916 Old 04-06-2013, 08:41 AM
gtang11's Avatar
Great info. Thanks.
gtang11 is offline
post #2460 of 2916 Old 04-06-2013, 08:59 AM
Quoted: 82 Post(s)
Liked: 176
Thanks, so far no dead pixels, no banding, very limited slow down/ picture stuttering.
Surprisingly, my settings looked great on all three panels, especially my current one.
I'm still tempted to put this HDTV through torture tests and set up the exchange for a F8000.
Right now I'm going to stick with the ES7100 as this panel has excellent resolution and motion.
I noticed new details in material I'm very familiar with.
I wonder if its a "newer" panel as I didn't see the manufacture date this time.
Reply LCD Flat Panel Displays
Samsung Un46es7100 Led Hdtv , Samsung Un60es7100 Led Hdtv , Samsung Un55es7100 55 Inch 1080p 240 Hz 3d Slim Led Hdtv Black
