Official Samsung UNXXES7100 Thread. - Page 98 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #2911 of 2916 Old 01-08-2016, 12:57 PM
Jedi2155's Avatar
This just started happening on my UN55ES7100 when my TV was updated to the latest firmware earlier last week. Now my wifi doesnt start up and the TV occasionally reboots on its own.
I went into the service menu and notice that the WiFi MAC address began reporting fail.....
Anyone have a solution besides pulling off the module? Anyone contact Samsung Support?
Sent from my SM-N920T using Tapatalk
Jedi2155 is offline
post #2912 of 2916 Old 01-10-2016, 05:29 PM
funny guy's Avatar
I had this same problem and eventually any time I accessed the smart hub or network settings it would lock up the TV. Replaced the WiFi module and problem solved. Part number BN59-01148 with either an A, B or C ending. My TV would turn back on when I turned it off, that was my very first symptom. Good luck!
Jedi2155 likes this.
funny guy is offline
post #2913 of 2916 Old 02-01-2016, 12:09 PM
BlluePill's Avatar
This has nothing to do with update right?
BlluePill is offline
post #2914 of 2916 Old 03-28-2016, 03:15 PM
pappaduke's Avatar
Quoted: 162 Post(s)
Liked: 153
Mount TV to a stand
I'd like to mount set to a stand, but I need 9" of clearance between the top shelf and the bottom of the set. It's a 60" model. Anyone doing this or know of a stand that can accommodate my spacing?
Yamaha 2010
Oppo 103D,ATV3,PS3, Samsung UN60ES7100F, Bluesound Vault 2 and Pulse Mini, Harmony One, Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's. B&W P5
Zone2-Paradigm SE-1's, Zone3-Paradigm-Stylus 370-SM
pappaduke is offline
post #2915 of 2916 Old 07-18-2016, 10:26 AM
Justinsane87's Avatar
I recently noticed a weird display issue with my Samsung UN55ES7100 and I'm hoping someone here may be able to tell me what's going on.
I've noticed that after the tv is on for 30 minutes or so, it will blink and the screen will auto adjust from Screen Fit to 16:9 and locks it in that screen size across all inputs.
The only solution is to turn off/on the tv and wait 30 minutes for it to happen again.
I discussed this with Samsung support who told me to reset the tv and power cycle it. When neither worked, they said the tv needs service.
Has anyone heard of this before or knows of a possible solution?
Justinsane87 is offline
post #2916 of 2916 Old 02-03-2017, 05:58 AM
rakosnicek's Avatar
Quoted: 26 Post(s)
I've updated to 02007 and I see some very strange behavior...
For some content, when I drag VLC from my PC's monitor to the TV, the TV will show the content until it becomes half and half on the TV/PC and any more, the TV goes blank and turns off the HDMI connection from the AVR. As soon as I remove VLC from the screen, picture is restored.
Has anyone else seen behavior like this?
rakosnicek is offline
Reply LCD Flat Panel Displays
Samsung Un46es7100 Led Hdtv , Samsung Un60es7100 Led Hdtv , Samsung Un55es7100 55 Inch 1080p 240 Hz 3d Slim Led Hdtv Black
