connecting my receiver to my new samsung led tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-13-2012, 10:30 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
i bought a new samsung tv and i thought it will be just like im using with my laptop, connect the hdmi and have 5.1, but i was wrong.
im trying to get my receiver to read what my tv is playing via USB.
is there anyway to do this?
in the manual it says something about running an optical from one side to the other but im not sure if this will work for playing movies via usb.
if this is true it will save me lots of $ on a streamer.
soler37 is offline
post #2 of 11 Old 06-13-2012, 01:55 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Huh? What? Que?
Stick your media in a USB dongle, plug USB dongle to back of TV. TV should be able to play. That's item#1.
Item#2: Are you not able to get audio from the TV -> Receiver? TV has a 2-page quick set up guide. Please make use.
MrBobb is offline
post #3 of 11 Old 06-13-2012, 02:19 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
tv wont read the receiver when i play movies from my usb.
works when i play my xbox.
i tried optical but it doesnt even read that, i cant even find the option of optical on the tv menu.
soler37 is offline
post #4 of 11 Old 06-13-2012, 07:22 PM
sitlet's Avatar
Again, not sure what you mean by "read"..
How is your xbox connected to the tv/receiver?
Should be in the audio settings menu. If you have an optical cable from the tv's optical output to the receiver's optical input, you will need to select Dolby 5.1. This might be the problem, if the media on your flash drive isn't encoded with DD 5.1.
sitlet is offline
post #5 of 11 Old 06-13-2012, 10:52 PM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
the question is, having an optical out in my tv - should i be to able to play movies from my flash drive through my receiver, what i mean is having the sound from the receiver and having picture from the tv, i do have movies that are encoded with 5.1.
i have the new samsung ua46es6200, i cant find the optical option in the menu.
soler37 is offline
post #6 of 11 Old 06-14-2012, 12:33 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
I have a feeling you are asking the question with the wrong terminology, hence we don't understand what ur asking. The above asks: can I USB -> Receiver (thorugh) -> TV. Have feeling that's not you mean.
First off, there is no menu selection for optical, it's always enabled, whether it ACTUALLY is giving u a signal is another matter.
AV connections can be made simple if u think in term of INPUTS and OUTPUTS. For example if I say XBOX -> TV -> Receiver, everybody knows what I mean. Note the direction of the arrows. Then you have to be aware most connections are ONE WAY (uni-directional), i.e.: TV HDMI are INPUT *TO* the TV only, therefore an HDMI connection can only be Receiver -> TV but NEVER TV (HDMI) -> Receiver. Again note arrows' direction. An AV receiver will have HDMI connectors for both input and output, labeled.
MrBobb is offline
post #7 of 11 Old 06-14-2012, 02:06 PM
Islandborn's Avatar
First of all, If you are talking about an optical out which is (toslink) that is a digital cable used to send audio data streams. We also need to know all your system specs. If you want to play movies via a some type of storage device, you have to make sure the tv or whatever you are plugging the usb device into can decode that format. If you can play the movie by plugging the usb stick into the tv, you can run the toslink optical cable from the tv to you avr receiver and set the receiver to tv, so you can have sound playing through you avr system.
Islandborn is offline
post #8 of 11 Old 06-14-2012, 02:08 PM
pds3's Avatar
Not sure I really understand your question but if you have a DVD or Blu ray player connected to your receiver (via HDMI) and the receiver is connected to the tv (via HDMI), all you have to do is plug in the flash drive to the DVD/Blu ray player which will then play the audio through your speakers and the video content to your tv.
pds3 is offline
post #9 of 11 Old 06-14-2012, 02:12 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
Are you putting a usb drive into the TV and then using the optical out on the TV to connect to the AVR? If so, don't expect DD 5.1 output from the TV to your AVR. It is meant only for DD 5.1 from OTA HD TV programming.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #10 of 11 Old 06-14-2012, 02:44 PM
sitlet's Avatar
Basically what everyone is saying, you need to fully explain your situation to use so we can answer your question. How is everything connected? Are you trying to play content from the flash drive through the tv or the receiver? You say it's encoded at 5.1, but is that Dolby or DTS?
sitlet is offline
post #11 of 11 Old 06-15-2012, 10:17 AM
topr's Avatar
First things first...eliminate the USB drive for now...do you get any audio back to your receiver from the Toslink audio out on your display when watching cable/sat/OTA programming?
topr is offline
Reply LCD Flat Panel Displays
