Hooking 60" Aquos to PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-16-2012, 10:20 AM - Thread Starter
golferstan's Avatar
Back in April I connected a 37" Vizio to a PC using RGB and audio cable. Watched Masters golf tourney from Masters.org before network tv action. Had great picture and sound.Vizio is just a few feet from PC.
Now I want to connect same PC to my Sharp Aquos using RGB and audio cable.Aquos and PC are 30 to 40' apart. Have tried and can get no picture using computer input on Aquos.
Any tips or suggestions on this project.
golferstan
golferstan is offline
post #2 of 6 Old 06-16-2012, 07:44 PM
gordon7's Avatar
go HDMI
gordon7 is offline
post #3 of 6 Old 06-17-2012, 10:20 AM - Thread Starter
golferstan's Avatar
PC does not have an HDMI port.
golferstan
post #4 of 6 Old 06-17-2012, 11:02 AM
gregzoll's Avatar
Liked: 33
If it is a desktop, get a video card with hdmi. If a laptop, you can get USB to HDMI converters.
gregzoll is offline
post #5 of 6 Old 06-18-2012, 03:38 PM - Thread Starter
golferstan's Avatar
gregzoll
Thanks for reply.
Since I can use Vizio off this PC with RGB and view as monitor,can I do the same thing with my Sharp?I switch inputs on Vizio and watch cable or change to RGB and watch on-line content such as streaming sports events.
golferstan
post #6 of 6 Old 06-18-2012, 05:25 PM
gregzoll's Avatar
Liked: 33
Depends on if the Sharp has a vga input. If it doesn't, you will need to see my reply and go from there, in getting HDMI output on your computer.
gregzoll is offline
Reply LCD Flat Panel Displays
