Difference between 120 Hz & 240 Hz LED (native)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-24-2012, 07:06 AM - Thread Starter
redtilldead's Avatar
Hello,
I am on the verge of buying the Samsung ES6800. However, one area of concern I am having is that this set is only 120 Hz native (not 100% sure but I thinks that's the case). Bearing in mind the set's steep cost, this was a bit of a let down.
My question is, is there any real benefit of having a 240 Hz screen vs 120 hz? Im not looking for the Soap Opera Effect in movies.
I understand the Sammy has a 500 Hz Clear Motion Rate (CMR) but that will induce the Soap Opera Effect. Correct?
redtilldead is offline
post #2 of 3 Old 06-24-2012, 12:11 PM
walford's Avatar
If yoiu are not interested in motion smoothing to get the SOE and you are not interested in 3D the 120Hz is fine.
walford is offline
post #3 of 3 Old 06-24-2012, 09:36 PM
Hooterville's Avatar
I believe the difference is about $600.- $800. but I could be wrong. rolleyes.gif
Hooterville is offline
Reply LCD Flat Panel Displays
