help, LCD and LED tvs have spots and streaks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 06-27-2012, 02:17 PM - Thread Starter
nauc's Avatar
i got this....
http://www.costco.com/Browse/Product.aspx?Prodid=11746329&whse=BC&Ne=4000000&eCat=BC|90607|2341&N=4047302&Mo=22&No=1&Nr=P_CatalogName:BC&cat=74672&Ns=P_Price|1||P_SignDesc1&lang=en-US&Sp=C
when the pic pans across the sky or a wall, i can see light spots or streaks in the pic. its very dim, but its always there. its like a veil thats always there, but sometimes it harder to see than other times. when the picture pans, its easier to see. i can easily see it when i load the Netflix app, when theres a lot of red on the screen. i can also see it on close ups of peoples faces, esp if they move around a bit
thoughts? i already missed the 30 day return option, but i do have a 5 year warranty for it.
i was thinking maybe i could use the screen scrubber/pixel flipper, or whatever its called, thats part of Disneys WOW calibration disc. i have no clue if that will work, im new too all this
thanks
nauc is offline
post #2 of 31 Old 06-28-2012, 03:26 AM
John4721's Avatar
Originally Posted by nauc View Post
i got this....
and when the screen is showing lots of white, the white looks blotchy, or cloudy. its very dim, but its always there. its like a veil thats always there, but sometimes it harder to see than other times. when the picture pans, its easier to see
thanks
Did you buy it from Costco? According this their return policy is 90 days for TVs, and, in my experience, you can generally talk with them and get them to accept returns on electronics even beyond that point.
Could you post any pictures or photos of what you're seeing? Almost sounds like what some of the folks around here call the "dirty screen effect", but it's hard to say.
John4721 is offline
post #3 of 31 Old 06-28-2012, 12:22 PM - Thread Starter
nauc's Avatar
yes, i did buy my tv from Costco. i bought it online and i thought i read that i had 30 days to return it to a store, but ill double check.... thanks
heres some pics of other peoples TVs that kinda look like what my tv is doing, but mine looks more blotchy or cloud shaped vs streaks or perfect circles. mine also doesnt look as noticeable, but im worried it will get worse over time
450
450
nauc is offline
post #4 of 31 Old 07-01-2012, 03:09 PM - Thread Starter
nauc's Avatar
any thoughts?
thanks
nauc is offline
post #5 of 31 Old 07-01-2012, 05:13 PM
walford's Avatar
What settings have have you tried changing , such as reducing the backlighting, for picture mode you are using on the TV?
Do you possibly still have the store/retail settings with which the TV's ship instead of one of the Home modes in use?
walford is offline
post #6 of 31 Old 07-01-2012, 05:20 PM
PlasmaPZ80U's Avatar
Quoted: 2316 Post(s)
Liked: 716
those photos show vertical and horizontal banding, which is usually a LCD panel issue... all you can do for that is exchange the TV for another of the same model or consider another brand/model
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #7 of 31 Old 07-01-2012, 06:06 PM - Thread Starter
nauc's Avatar
heres what i have it set to, but ive played with all of these, which doesnt do much for the problem im having
Picture Mode = Custom
Backlight = in the middle
Contrast = same
Brightness = same
Color = same
Tint = same
Sharpness = same
Color Temp = Natural
Ambient Light Sensor = off
all other processing = off
there is a mode for Home or Store, i have it set to Home
i just checked my paperwork, i do have 90 days to return it
my BluRay player is supposed to be here Thursday. ill see how it looks with that
nauc is offline
post #8 of 31 Old 07-02-2012, 08:27 AM
walford's Avatar
Your pics appeasr only show the backlighting, I suggest that you lower the backlighting more and that you set the sharpness to 0. Then check with a program image on the screen and try your contrast and brightness settings.
walford is offline
post #9 of 31 Old 07-02-2012, 09:21 AM
Liked: 716
I'm very sure the OP has either banding like in the pics or DSE... not something that picture settings can fix.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #10 of 31 Old 07-02-2012, 05:03 PM - Thread Starter
nauc's Avatar
the pics i posted are not of my TV. i posted them to give everyone an idea of what my TV is doing. i dont have steaks or perfect circles like those in the pics. i have spots that are irregular. they look like clouds
nauc is offline
post #11 of 31 Old 07-02-2012, 05:33 PM
Liked: 716
In any case it is a screen uniformity issue or DSE and cannot be fixed by changing picture settings.
Rocko9999 likes this.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #12 of 31 Old 07-03-2012, 06:44 AM - Thread Starter
nauc's Avatar
what is DSE
thanks
nauc is offline
post #13 of 31 Old 07-03-2012, 10:37 AM
walford's Avatar
Reducing the backlighting can reduce the effects of banding. Setting the sharpness to 0 will not effect bandingt but can eliminate artifacts.
Since you have a 120Hz unit do you have motion compensation enabled? If no set it to a low value which can reduce image blur especially diuring panning scenes.
Have you tried the presets for any other home mode besides Custom?
Plasma may mean SDE (Screen Door Effect) and not DSE.
walford is offline
post #14 of 31 Old 07-03-2012, 10:47 AM
Liked: 716
like I said this is most likely a screen uniformity issue (panel and/or backlight based) and so it won't go away by lowering backlight since all that will do is make the whole screen dimmer, not more uniform
it could also be the dirty screen effect which has to do with the AR/AG coating on the screen being unevenly applied
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #15 of 31 Old 07-03-2012, 06:11 PM
walford's Avatar
Since the problem is most noticable when theri is a lot of white mytrain of thought is that the screenis too bright and should be reduced by lowering the backlighting and possibly changing the brightness or contrast.
With the representative 600 x450 jpg images in his post it is hard to really see the problem.
The following interesting post lists one users efforts to change and fix his system settings .
walford is offline
post #16 of 31 Old 08-02-2012, 11:34 PM - Thread Starter
nauc's Avatar
nauc is offline
post #17 of 31 Old 08-16-2012, 01:41 PM - Thread Starter
nauc's Avatar
yesterday i returned the Vizio and picked up the Samsung UN50EH6000, a backlit LED tv from Costco and sure enough, theres a big light spot, about the size of a human head, right in the middle of the screen
in disbelief, once again
nauc is offline
post #18 of 31 Old 08-16-2012, 02:55 PM
Liked: 716
the wonder of Samsung, lol
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #19 of 31 Old 08-16-2012, 05:51 PM - Thread Starter
nauc's Avatar
lol, yah, im blown away!
nauc is offline
post #20 of 31 Old 08-16-2012, 10:39 PM
mrkdilkington's Avatar
Time to try a plasma. They're known for their uniform light distribution.
mrkdilkington is offline
post #21 of 31 Old 08-16-2012, 11:29 PM
biznus97's Avatar
Look up plasma dse and you'll see the issue pops up there too. The anti-glare coating on a lot of flat panel sets isn't helping. For lcd it seems once you go over 42" banding and dse is almost unavoidable.
biznus97 is offline
post #22 of 31 Old 08-17-2012, 10:27 AM
Liked: 716
the Panasonic 50" ST50 is probably the best option at this point for a good mid-range plasma (with a dark screen filter for daytime viewing)
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #23 of 31 Old 08-17-2012, 10:37 AM
J.Mike Ferrara's Avatar
Quoted: 153 Post(s)
Liked: 179
Ok - this is the last time I will post this, so please pay attention:
IF YOU WANT A THIN FLAT PANEL LED, YOU MUST BE WILLING TO PUT UP WITH VERTICAL/HORIZONTAL BANDING, DIRTY SCREEN EFFECT, LIGHT BLEEDING FROM THE EDGES, POOR UNIFORMITY, AND BLOBS OF LIGHT OR DARK AREAS.
IT IS VISABLE ON EVERY SINGLE SET OUT THERE - SOME ARE WORSE THAN OTHERS. I'M ON MY 6TH SET, AND I'VE VIEWED 100s.
BTW, Plasma may be better in regards to screen uniformity, but it has it's own issues.
BUYER BEWARE. YOU HAVE BEEN WARNED.
J.Mike
Those who die with the most toys ... are still dead!
J.Mike Ferrara is offline
post #24 of 31 Old 08-17-2012, 10:53 AM
Liked: 716
nothing's perfect (pick your poison), but some LED-LCDs are definitely worse than others and some people are pickier about screen uniformity than others (I am very picky about screen uniformity issues which is why I avoid all edge-lit LED-LCDs)
Samsung seems to have the most issues in this area with their LED models, especially on the ES series (though some samples can be pretty good relatively speaking... yet the majority are not).
BTW, which makes/models have you gone through? Perhaps that info can help others here trying to decide what to exchange/return and what to settle for.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #25 of 31 Old 08-17-2012, 11:38 PM
Yes exactly, pick your own poison. For me backlight bleed is the worst poison of all wink.gif
post #26 of 31 Old 08-18-2012, 04:40 AM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
My 70LE845U is edge-lit and has none of the problems you describe.
My calibration runs it at 50% backlight and the black level is uniform across the screen
and all colors display evenly, with no hot or dark or dirty spots to be seen.
My big issue is the native color of the LEDs themselves, which concentrate in the blue band.
As they age, they will lose more and more of their green, yellow and red capabilities.
Reds, in particular, clip early in order to maintain intensity comparable to the blues.
I hope the science of cold lighting takes a turn for the better and soon...
johnfull is offline
post #27 of 31 Old 08-18-2012, 11:09 AM - Thread Starter
nauc's Avatar
heres the 3 tvs that ive had problems with...
JVC JLC47BC3000 (LCD) = had 2 bright spots on it, and a few, brighter, angled streaks
Vizio E472VLE (LCD) = had 2 bright spots on it, and a bunch of brighter, vertical streaks
Samsung UN50EH6000F (Backlit LED) = has 1 large, brighter spot, right in the middle of the screen
nauc is offline
post #28 of 31 Old 09-04-2012, 09:40 PM
bananafi5h's Avatar
Samsung un40eh5000
Backlit LED TV
showing vertical and horizontal banding on 10% and 20% full gray screen.
bananafi5h is offline
post #29 of 31 Old 09-04-2012, 09:49 PM
Jacob305's Avatar
Quoted: 85 Post(s)
Liked: 48
I second the motion. I will never go back to lcd after getting a plasma. granted plasmas have their own problems. but its much easier to deal with the lcd problems.
Jacob
Jacob305 is offline
post #30 of 31 Old 10-05-2012, 12:14 AM
The Mice's Avatar
Quoted: 109 Post(s)
Liked: 249
I tend to agree. Previously I was using a 42" Panasonic plasma which had a great picture without any flaws, now I have an LG 55LW5000 which definitely suffers from the dirty screen effect. Based on my experience, I definitely would go back to plasma for my next TV.
The Mice is offline
Reply LCD Flat Panel Displays
