Which 2012 LG 47" TVs use IPS panels, if any? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-29-2012, 09:01 AM - Thread Starter
LordJezo's Avatar
How can I tell if LG is using an IPS panel on their 2012 TVs? I dont see them listing it on their website anywhere.
LordJezo is offline
post #2 of 4 Old 06-29-2012, 09:28 AM
Otto Pylot's Avatar
Quoted: 1378 Post(s)
Liked: 863
What you could do is go to your local B&M and do a loupe test on all 2012 LGs that you are interested in. Write down the complete product code and your results. That way, you can get an idea, by product code, which 2012 LGs should have an S-IPS panel. Someone had mentioned earlier that the "Y" designation (fourth position in the product code) for the 2012s still indicates an S-IPS panel like it did for the 2011s. I haven't confirmed that myself though.
Otto Pylot is online now
post #3 of 4 Old 06-29-2012, 05:26 PM
Guibs's Avatar
If I am not mistaken, at that size, they will all be IPs panels. LG is about the only panel manufacturer to create 47" panels and LG only make IPS panels.
could be wrong but I think it's a fair bet that at that size, you will get an IPS panel.
Guibs is offline
post #4 of 4 Old 06-29-2012, 09:04 PM
Otto Pylot's Avatar
Liked: 863
Which IPS? S-IPS, E-IPS, etc.. A lot of us prefer S-IPS.
Reply LCD Flat Panel Displays
