Moving From Pioneer Kuro to LCD/LED - What models have comparable black levels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-02-2012, 09:11 PM - Thread Starter
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
I've had the Pioneer Kuro 5080 for a few years now and it's a phenomenal TV, even if it's "only" 720p. I'm getting the itch to "upgrade" to a 60" or larger LCD/LED, but am very concerned that I won't be able to find something with as good or better black levels. To anyone who may have moved from the Kuro, what LCD/LED HDTVs have the best true contrast ratios that I'd be happy with?
MidnightWatcher is offline
post #2 of 6 Old 07-02-2012, 09:46 PM
Hotthree's Avatar
I think Sharp is the only thing that gets close. Maybe the es8000 from Samsung might be the next choice from there.
Hotthree is offline
post #3 of 6 Old 07-03-2012, 12:24 AM
Joxer's Avatar
Why not the 2012 Panasonic plasma models? They are reportedly the closest to a Kuro in black levels now and in the same size range are far cheaper than the very expensive high-end LED models with non-edgelit backlighting.
The edge-lit models have flashlighting and clouding in dark scenes viewing in a dark environment in contrast.
Joxer is offline
post #4 of 6 Old 07-03-2012, 07:51 AM
Fanaticalism's Avatar
Only the Sharp Elite equals the Kuro in black levels and for an LCD is similar in other areas. The only other panel with comparable blacks/ansi would be the VT50 from Panasonic.
Fanaticalism is offline
post #5 of 6 Old 07-03-2012, 11:50 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
you'd likely be happiest with the panasonic VT50 plasma
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #6 of 6 Old 07-03-2012, 03:20 PM
kesando's Avatar
Liked: 31
Find a place where you can check out the Elite Pro X5 LED/LCD and Panasonic VT50 Plasma side by side. These are your best choices from each panel technology.
kesando is offline
Reply LCD Flat Panel Displays
