UNxxES7500 and UNxxES8000 - AVS Forum | Home Theater Discussions And Reviews
Old 07-06-2012, 03:55 PM - Thread Starter
Riftburn's Avatar
Hey all
Iv been pouring through the posts on both of these two displays, and have pretty much narrowed it down to one or the other. However I have just one question that I haven't been able to find a good answer to.
What I'm trying to find out is if these two TV's essentially have the same panel inside, and if not is there a huge difference between the two? From what I can tell the 8000 has the higher contrast as well as the Micro dimming Ultimate. Besides that I can't find any other differences with the exeption of the stand which I don't really care about anyways cause its going to be wall mounted.
The final thing I'm struggling with is if its worth it to spring for the 8 series over the the 7 based of those differences that I have been able to find.
Any help is greatly appreciated and thanks in advanced!
Riftburn is offline
Old 07-06-2012, 09:16 PM
HenDokuYaku's Avatar
Riftburn,
I suggest you look in the es8000 owners thread and you will see that discussed several times. I have had both panels and find the difference noticable.
HenDokuYaku is offline
