Got a "Free" 19" Samsung LED, worth keeping? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-13-2012, 04:55 PM - Thread Starter
Hooterville's Avatar
Purchased the UN60ES7100 at HHgregg a couple of weeks ago and I see now that they are giving away a free 19" Samsung LED with this set. Went by there today and they gave me the free 19 inch LED.
It's model number is UN19D4003 and I was wondering if anyone has this little TV? Worth keeping as a spare set or dump it on Craig's list for a quick $100.eek.gif
Hooterville is offline
post #2 of 7 Old 07-14-2012, 06:03 AM
BoilerJim's Avatar
Quoted: 55 Post(s)
Liked: 118
Depends if you need it or not. Hook it up, turn it on, try it out, and then decide.
BoilerJim is offline
post #3 of 7 Old 07-14-2012, 07:47 AM
dfp
dfp's Avatar
If you have cable, split the signal before the cablebox, run the new coax into the RF input, scan for cable channels, and get all local broadcast channels in HD and some cable channels in SD.
Place the set nearby, giving you more functionality than picture-in-picture, and making it easier to keep up with more football games this fall.
dfp is offline
post #4 of 7 Old 07-14-2012, 11:27 AM - Thread Starter
Sounds like a good idea but we have DirecTV and I don't think we will get anything without another HD box from Direct. smile.gif
post #5 of 7 Old 07-14-2012, 04:24 PM
dfp
dfp's Avatar
You're right. :-) If you live within 24 miles of local broadcasters, you could pick up an RCA ANT1250 amplified indoor loop antenna for about $39 and get all local stations in HD. If they are near each other, you won't even have to turn it. Go to www.antennaweb.org to see.
dfp is offline
post #6 of 7 Old 07-14-2012, 04:59 PM
Phase700B's Avatar
Liked: 25
Doesn't DirecTV have receivers with two or more tuners so that you can watch different programs on up to 4 TVs?
Or put and RCA antenna in the attic with a RG6 coax down to the free 19" TV. Depending on how far you are form TV stations you may be surprised at what you get.
Phase700B is offline
post #7 of 7 Old 07-14-2012, 06:57 PM - Thread Starter
I believe that they do. We already have 2 HD receivers from Direct and our bill is like $100. a month already. I might hook it up to an over the air antenna and see what I get.smile.gif
Reply LCD Flat Panel Displays
