Sony Bravia KDL52XBR4 - Screen distortion, fluttering - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-16-2012, 10:35 AM - Thread Starter
networm's Avatar
Hi All,
The ghosting and fluttering is concentrated on the left side, there are also 3 thin lines through the middle.
Recently i started seeing the streak on the TV and they are more on the left side of the screen. Below are the picture that shows the exact symptoms -
448
448
448
448
The symptoms are same on all different inputs (Dish and Cable) and this shows on both. The issues stays when the TV starts and after tapping gently (little harder at times) on the front of the lcd panel makes the distortion goes away. At times - hitting it three four times with all four finder tips makes it go away, and at worst it needs hard tapping on the back of the panel as well.
Serial # 8147488
Model # KDL52XBR4
PD # Dec 2007
What seems to the issue here? Is it bad T-CON Board?
Did i used the right words (distortion, fluttering) for the issue that I have after reviewing the images above?
Thanks for your time and input in advance.
Networm.
networm is offline
post #2 of 3 Old 07-17-2012, 05:43 AM
schlick's Avatar
Read the first page of this thread. About halfway down (post 29) there's a DIY fix that some have had success with. Good luck.
http://www.avsforum.com/t/1173106/kdl-xbr4-half-the-screen-dark-with-slow-pixel-refresh-all-inputs
schlick is offline
post #3 of 3 Old 01-20-2014, 07:11 PM
Goran 1989's Avatar
Hi there,
I have the same problem with my tv! Can u please share with me how you fixed it and how much did it coast?
Many thanks,
Goran
Goran 1989 is offline
Reply LCD Flat Panel Displays
Sony Bravia Xbr Kdl 52xbr4 52 Inch 1080p Lcd Hdtv
