Best 55" Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-23-2012, 01:52 AM - Thread Starter
Jhara's Avatar
For someone who predominately watches 2D content - Blu Ray, 1080p and gaming on PS3 which 55" LCD TV provides the best picture quality, I was considering the Sony 55HX929 or something in a similar price range?
Jhara is offline
post #2 of 9 Old 07-23-2012, 12:11 PM
8mile13's Avatar
Quoted: 1479 Post(s)
Liked: 825
the XBR HX929 is probably the best 55inch LCd right now.
its a full array Local Dimming LED LCd
LED TVs compared:
http://reviews.cnet.com/2795-6482_7-399.html
Eventhough i like/enjoy watching movie's in a nearly dark environment on my LCd lot of folks on AVS believe that Plasma will give you the best movie experience so you also should consider this years Shootout winner the Panasonic VT50 Plasma
Djyinn likes this.
8mile13 is offline
post #3 of 9 Old 07-23-2012, 05:53 PM
TechFan84's Avatar
I second the Panasonic VT50 plasma, along with the ST50 if you're looking for something in a lower price range. As for the Sony sets, in addition to the XBR model, you should look into the KDL - HX850 model for its excellent picture quality and deep blacks for an LCD. This is a bit pricier than the Panasonic sets, so I'd recommend comparing prices to find the best deal before making a final decision.
TechFan84 is offline
post #4 of 9 Old 07-24-2012, 07:13 AM
6athome's Avatar
Quoted: 354 Post(s)
Liked: 133
The LG LV9500 local dimming! Leave this TV on and shut out the lights and look how black it is.
With the bluray legend on, wait till Will Smith closes all the shutter,their is noting,you can not see the TV,it is like a black hole.
Try that with plasma or edge lit !
6athome is offline
post #5 of 9 Old 07-24-2012, 07:31 AM
Alexei Volkoff's Avatar
was checking also for the best 55inch tv
your option for 2012
samsung un55es8000
sony hx850
panasonic wt50
lg lm9600
and yeah thats about it
Alexei Volkoff is offline
post #6 of 9 Old 07-25-2012, 06:05 PM
steve1022's Avatar
Quoted: 81 Post(s)
Liked: 65
Best Buy has the plasma Panasonic 55" st50 on sale for $1299 this week. I don't have it but reading the owner thread here it sounds like a steal.
Djyinn likes this.
PSN: ROLL_mf_TIDE
steve1022 is offline
post #7 of 9 Old 07-25-2012, 06:13 PM
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
regarding the WT50, this year's lineup of Panasonic LED-LCDs has received poor reviews across the board by CNET.
http://reviews.cnet.com/flat-panel-tvs/panasonic-tc-l55wt50/4505-6482_7-35118293.html?tag=results;prodInfo
"The good: The Panasonic TC-LWT50-series LED TV showed the best off-angle performance of any LCD I've tested, and its screen was quite uniform. Its 3D performance was good with little crosstalk. The styling is sleek with an ultrathin frame and unique horseshoe stand. Plenty of useful features are onboard, including a well-designed Smart TV suite and a touch-pad remote.
The bad: The high-priced WT50 has a sub-par 2D picture, reproducing a lighter shade of black than many cheaper LEDs. Panasonic inexplicably saddled the best default picture mode with compulsory smoothing, and the other modes have color accuracy issues. The TV doesn't come with 3D glasses.
The bottom line: Class-leading quality from off-angle can't excuse the expensive Panasonic TC-LWT50's disappointing picture when seen from the sweet spot.
Picture settings: Unlike Panasonic's high-end plasmas the WT50 doesn't have a THX mode, but otherwise it does have most of the picture adjustments offered on the flagship VT50. Unfortunately, they don't work as well.
Both the Cinema and Custom modes offer niceties like a color management system, selectable gamma (no 10-point gamma like the VT50 however), and a multipoint grayscale control (although it's a weird 7-point system, not the standard 10). Cinema is basically broken for videophiles, however, because it inexplicably omits the ability to disable dejudder/smoothing -- the Motion Picture Setting is stuck at Strong in Cinema, causing the infamous, obvious Soap Opera Effect and accompanying artifacts in film-based material. Custom does allow you to disable dejudder, but its color performance isn't nearly as accurate as Cinema despite plenty of controls. See below for more details.
Connectivity: Plenty of inputs, including four HDMI, three USB, and a PC input, grace the WT50's backside. Component- and composite-video connections require use of the included breakout cable.
Picture quality
Picture settings:
Panasonic TC-L47WT50
All told the WT50's image quality is significantly worse than you might expect from a high-end LED TV. The TV's depth of black is worse than a few mid- and entry-level models we've tested, color is inaccurate, and there's no way to fix it because the controls don't work properly. I appreciated the excellent screen uniformity, highlighted by best-in-class off-angle fidelity, but it's not nearly enough to overcome the WT50's faults.
Click the image at the right to see the picture settings used in the review and to read more about how this TV's picture controls worked during calibration.
Comparison models (details)
Samsung UN55ES8000 55-inch edge-lit LED
Sony KDL-55HX850 55-inch edge-lit LED
Toshiba 50L5200U series 50-inch edge-lit LED
Panasonic TC-P55ST50 55-inch plasma
Samsung PN60E8000 60-inch plasma
Black level: Like the other Panasonic LCDs we've tested this year, the WT50 had trouble mustering a convincing depth of black. The TC-L47WT50 I reviewed produced the lightest shade of black in our lineup. Its letterbox bars and shadowy areas, for example the tunnel and shadowy alley from "Sherlock Holmes: Game of Shadows" (1:21:46), appeared markedly brighter and less realistic than on the Toshiba and Samsung, while the Sony and the plasmas looked better still. The difference was mainly visible in dark scenes but spilled over into brighter ones as well.
I didn't include any of Panasonic's other LCDs in the lineup but judging by my measurements of 0 percent black -- the WT50 got 0.039, the E50 0.054, and the DT50 a terrible 0.24, and all three rate "Poor" by my Geek Box chart standards -- Panasonic's edge-lit local dimming system, exclusive to the WT50 among the three, isn't that effective.
Beyond the lighter blacks I also noticed a more washed-out quality in many scenes, both bright and dark, caused by too-bright gamma. The WT50 had no problems conveying details in shadows, but the progression from dark to light was too abrupt, making dark areas look less natural. The other sets looked more realistic in comparison and showed better punch.
Unlike the Samsungs and the HX850, the WT50's backlight didn't turn off completely during fades to black, for example during the intro to "Watchmen," and that's a good thing. The issue did occur when we switched to Cinema or Custom mode, however.
Color accuracy: Again the WT50 fared worse in this area than any other TV in our lineup. The skin tones of Moriarty and Adler in chapter 2 (10:09) looked much like the other colors in comparison: pale and slightly sickly. This was mainly because I had to desaturate the image to make up for significant over-accentuation of red in the Panasonic's color balance.
Another problem, made more visible by the lighter black levels, was the WT50's tendency to plunge into blue in black and near-black areas. None of the other TVs showed as severe a blue tinge when reproducing dark material.
Video processing: As I mentioned above, the WT50's main problem in this area is that Cinema is stuck in smooth mode, rendering it useless for people who prefer to see film the way the director intended -- typically, with judder. The control that causes smoothing, labeled "Motion Picture Setting" and offering four settings (Off, Weak, Medium, and Strong), is only adjustable in the other picture modes.
Choosing Off caused the TV to correctly reproduce film cadence with 1080p/24 sources. Interestingly, Weak also came very close to ideal cadence too, betraying just the merest hint of smoothing in my test. That setting may be preferable to Off for slightly less hardcore film buffs who want to take advantage of the superior motion resolution afforded by engaging dejudder on this TV.
The Panasonic scored the full 1,200 lines in my motion resolution test when I choose Strong or Medium, falling to a still-respectable 900 to 1,000 in Weak and the typical 300 to 400 lines in Off. As usual I found it nearly impossible to detect blurring or other traces of low motion resolution in normal program material, so I was fine keeping it set to Off.
Uniformity: From the standpoint of maintaining consistent light output over the entire area of the screen, as well as image fidelity when seen from off-angle, the WT50 displayed excellent screen uniformity.
Unlike most other edge-lit LEDs I've tested, the WT50's screen was pretty much free of bright spots and clouding. Its light black levels may help in this regard, effectively masking any imperfections, but either way the WT50 deserves a lot of credit here.
Even more impressive is its ability to maintain picture fidelity when seen from angles to either side of the sweet spot right in front of the TV. Compared with the Samsung and Toshiba, both of which have better black levels from on-angle, the WT50 actually delivered a slightly darker black when seen from angles as close as one seat cushion to either side (tested from a 7-foot seating distance). It also maintained color fidelity better, taking much longer to show a shift toward red or blue.
Move farther to either side and that advantage increases; when seen from extreme angles, the WT50 blows any other LED TV (including the DT50 and E50 we tested) out of the water. Of course, most people watch TV from the sweet spot or close to it, and sit farther away than 7 feet. For them, the WT50's off-angle prowess will be much less valuable.
It's also worth noting that even from less extreme angles the WT50 still lost some picture quality, and that loss increased the farther off-angle we moved. In other words it's still no plasma, a technology that maintains essentially perfect quality from any angle.
Bright lighting: Under the lights the WT50 behaved similar to the Sony and Samsung sets, with bright, distracting reflections and the ability to reject some ambient light to preserve black levels. Of course its initial black levels were bad enough that it didn't make the set look better than the others in this regard.
3D: The 3D picture of the WT50 was excellent in one crucial area: crosstalk reduction. As long as I chose the 48Hz option under the Advanced picture menu, the TV did as good a job of quelling the annoying double-image of crosstalk as the superb Samsung UNES8000, and outperformed the other sets in the lineup. My crosstalk torture test is "Hugo," namely problem areas like Hugo's hand as it reaches for the toy mouse (5:01), the tuning pegs on the guitar (7:49), and the face of the dog as it watches the inspector slide by (9:24). In these areas the ghostly double image was almost invisible.
The WT50's Cinema mode again has non-defeatable smoothing, so I switched to Standard and the Warm color temperature as the best available preset (I don't calibrate TVs for 3D). In that mode color was pretty bad, significantly redder than any of the other sets. It was also dimmer than either of the other two LEDs, in particular the excellent Samsung. Aided by the glasses, black levels were better than 2D but still not great, especially compared with the inky plasmas.
Panasonic's standard 3D glasses fit better than the Samsungs and provided marginally better performance since they enclosed my eyes more thoroughly, shutting out more ambient light. Check out my comparison and reviews for more.
Geek Box test Result Score
Black luminance (0%) 0.039 Poor
Avg. gamma 1.82 Poor
Near-black x/y (5%) 0.2898/0.3011 Average
Dark gray x/y (20%) 0.3111/0.3316 Average
Bright gray x/y (70%) 0.3115/0.3287 Good
Before avg. color temp. 6563 Good
After avg. color temp. 6567 Good
Red lum. error (de94_L) 9.2212 Poor
Green lum. error (de94_L) 0.2291 Good
Blue lum. error (de94_L) 2.6271 Average
Cyan hue x/y 0.2293/0.3281 Good
Magenta hue x/y 0.3108/0.1502 Average
Yellow hue x/y 0.4269/0.519 Poor
1080p/24 Cadence (IAL) Pass Good
1080i Deinterlacing (film) Pass Good
Motion resolution (max) 1200 Good
Motion resolution (dejudder off) 300 Poor"
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #8 of 9 Old 07-26-2012, 10:20 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
LED TVs compared:
agree
Djyinn likes this.
zoro is offline
post #9 of 9 Old 07-27-2012, 04:40 PM
waterm3732's Avatar
If you are a serious gamer playing games where short reaction times are critical, don't forget to do a little research on this website to find the display's shortest lag time (some offer a gaming mode just for this purpose). Lag time is the time between when the signal is inputed to the time it is displayed on the screen.
waterm3732 is offline
Reply LCD Flat Panel Displays
