UN50ES6500 - Too Liquid Smooth? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-25-2012, 09:59 PM - Thread Starter
bowmah's Avatar
ok, just got back at a friend's place. Saw their new 50 inch LED UN50ES6500 Samsung Smart TV. Why is the picture overly smooth and liquid like it's an HD camcorder effect? Is there any motionflow stuff that you can disable on this model? Looks totally un-natural. Almost like taking a non 3D movie and making it 3D after the fact! Any ideas?
bowmah is offline
post #2 of 2 Old 07-25-2012, 11:59 PM
BriscoCountyJr's Avatar
Quoted: 33 Post(s)
Liked: 42
Thats the so-called "Soap Opera Effect" which is the TV doing frame interpolation to convert to a higher displayed frame rate.
You can go into one of the advanced picture settings to adjust that effect to varying degrees - look for more info in the e-help info on picture settings on the TV.
BriscoCountyJr is offline
Reply LCD Flat Panel Displays
Samsung 50 Inch Class Smart Tv 3d Slim Led Hdtv Un50es6500
