LCD's that output 2 channel digital audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-27-2012, 01:37 PM - Thread Starter
alexwgoody's Avatar
I am usually a stereo only audio guy, but I want a cheap 32" lcd tv from which I can play the sound through my 2 channel system. Ideally I would do this by using my 2 channel DAC with optical from the TV, but most Tv's output multi channel audio only through optical or digital coax. Does anyone happen to know a TV that outputs either optical or digital Coax with an option of 2 channel? I've been googling like crazy and calling some companies, but it seems to be very uncommon (and yes, I know it is an uncommon demand and that they have RCA, but digital should sound better through my gear)
Thank you
alexwgoody is offline
Reply LCD Flat Panel Displays
