Best 46" - 55" LED TV primarily for SD viewing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-08-2012, 08:56 AM - Thread Starter
The_Frock's Avatar
After urgent advice as i want to make a purchase within the next couple of days.
As implied, I'm looking for a 46" - 55" LED tv who's primary sources will be standard definition free to air tv (via component), and downloaded SD tv shows (via HDMI and WiFi).
I realise that plasma is the way to go, but the tv is for my smallish bedroom which doesn't have any air con. Having previously owned a plasma, the heat it radiated was considerably annoying during summer, hence my want for an LCD.
It requires to roughly fall below the 55ES8000 price range. Unfortunately, i cannot afford a Sharp Elite Pro.
From the little info i've managed to find on the net, i've come to the conclusion that either HX850 or ES8000 are my best options. Am i right? If so, which of the two? If neither, please advise!
Many thanks in advance,
Jonathan Rocco
The_Frock is offline
post #2 of 8 Old 08-08-2012, 09:04 AM
PlasmaPZ80U's Avatar
Quoted: 2318 Post(s)
Liked: 716
Originally Posted by The_Frock View Post
I'm desperately after your advice as i want to make a purchase asap.
As implied, I'm looking for a 46" - 55" LED tv which will primarily be used for viewing free to air standard definition tv, and downloaded tv shows.
I realize that plasma is the way to go, but the tv is for my smallish bedroom which doesn't have any air con. Having previously owned a plasma, the heat it radiated was considerably annoying during summer, hence my want for an LCD.
From the little info i've managed to find on the net, i've come to the conclusion that either HX850 or ES8000 are my best options. Am i right? If so, which of the two? If not, please advise!
Jonathan Rocco
the HX850 is better
http://reviews.cnet.com/flat-panel-tvs/sony-kdl-55hx850/4505-6482_7-35118056.html
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #3 of 8 Old 08-09-2012, 06:03 AM - Thread Starter
The_Frock's Avatar
thanks for the link PlasmaPZ80U - i've come across that review before - unfortunately it doesn't seem to give much insight into SD viewing?
post #4 of 8 Old 08-09-2012, 10:58 AM
Liked: 716
CNET stopped testing SD PQ a while ago as did ConsumerReports.org. I would imagine the reason for this being that most are able to get HD content quite easily at this point (OTA HD, HD Cable/Satellite, HD console gaming, BD movies and TV shows, HD streaming/digital downloads of video content, etc.).
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #5 of 8 Old 08-09-2012, 11:00 AM
Liked: 716
In any case, Samsungs are generally known for excellent processing of SD content.
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
Rythmik LV12R
post #6 of 8 Old 08-09-2012, 11:08 AM
jilla60's Avatar
Although cheap and some don't like it, I like my 55L6200U Toshiba LED TV. I watch a lot of SD on DISH (South Asian channells). They look good to me compared to my last year Samsung. For HD, Samsung & Toshiba are equally good, but for SD content (Mostly channells) Toshiba is far better. It is also cheap and can be found for $1200 for 55".
Also you should think about investing in DVDO EDGE ($400 at Amazon now) if you watch a lot of SD stuff. That will help making SD content much better. If you have more money, you can buy Onkyo 818 ($1100 now, was on sale earlier for $829 at Amazon).
Note : I am not even close to an expert, and hence my opinion is based on my viewing only! biggrin.gif
jilla60 is offline
post #7 of 8 Old 08-09-2012, 01:57 PM
PeterG's Avatar
Liked: 25
Here is a review from an excellent UK review site which deals specifically with SD performance. Ignore the bit about 2-2 Pal telecine transfers as it is not applicable to North Americans:
http://www.hdtvtest.co.uk/news/samsung-ue55es8000-ue46es8000-201205301790.htm?page=Performance This is for the ES8000 but the ES7000 would be the same.
As regards the HX850 here is the page dealing with SD too.
http://www.hdtvtest.co.uk/news/sony-kdl-55hx853-46hx853-201206161860.htm?page=Performance
Of the two, it appears the Samsung does better. You don't have to go with the ES8000 - the ES7000 would be very similar (the ES7000 is also reviewed there).
PeterG is offline
post #8 of 8 Old 09-01-2012, 10:04 AM
Srujan Sujju's Avatar
SONY HX 850
SONY TABLET S - SONY DSC-WX7 - SONY HOME THEATER - SONY MDR XB - 500 - SONY NWZ-A844/T - SONY HX 850 -SONY PlayStation®3 160GB Console( UPCOMING )
Srujan Sujju is offline
Reply LCD Flat Panel Displays
Led Hdtv , Sharp , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv
