Require 32" or Bigger TV for Reception Area in a Clinic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-10-2012, 07:39 AM - Thread Starter
Malbojia's Avatar
Good day Everyone,
I am currently out of the loop when it comes to LCD's, LED's and Plasma TV's since 2007. What I would require is a TV of a minimum size of 32 inches that will be used in the reception area of a Clinic.
This means it will be on for extended period of time. Also I would need for it to support wall mounting or via brackets.
Are Plasma's still doing burn in's for when they are left on a static image for a duration of time? Do LCD's still have that lighting half life once they are past a certain number of hours.
Thank you for your input.
Malbojia
Malbojia is offline
post #2 of 2 Old 08-10-2012, 08:18 AM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
I would buy the cheapest set i could find 40" LCD ( LCD = less power and heat ) and let it run till it dies and then repeat. Who cares about PQ you just need a bright display. Leave it on 24 - 7 and you'll probably get a little longer life out of it. Heating up and cooling off is the killer in electronics.
RollTide2011 is offline
Reply LCD Flat Panel Displays
Lcd Hdtv , Led Hdtv , Plasma Hdtv
