Sony Bravia > Pandora > Speakers = No sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-10-2012, 12:16 PM - Thread Starter
AVSBurger's Avatar
Okay, I'm going to try to use new technology to post this question. I did a video really quick and uploaded it to Vimeo. Can you let me know if you have a solution? I can't figure this out. I need to get the speakers working by tonight. Thanks so much everybody.
If you don't want to watch the video, the problem is I am trying to play Pandora on my Sony Bravia TV, using its Wi-Fi. There is no sound coming out of the left or right front speakers. Only the sub woofer. I have a Sony receiver, and the speakers are properly attached. They all work fine when the television is on. Going through the cable DVR box.
But when I set the receiver to television as the output, I only get sound out of the sub woofer. So basically the receivers not putting sound out through left and right front speakers.
I guess it's possible that only center sound comes out with Pandora on the TV, but that would be ridiculous, as this should be at least stereo sound.
AVSBurger is offline
post #2 of 4 Old 08-10-2012, 02:39 PM
Super Moderator
DrDon's Avatar
Quoted: 881 Post(s)
Liked: 1745
Since this not a question about high definition television, I'm moving the thread to the display area.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #3 of 4 Old 08-10-2012, 03:28 PM - Thread Starter
AVSBurger's Avatar
I wasnt sure where it goes since its a question about High Definition Televisions (The Sony Bravia which has Pandora built into it) .... and the receiver involved ... and the speakers connected.
Anyone have any idea on a solution?
post #4 of 4 Old 08-10-2012, 04:11 PM - Thread Starter
AVSBurger's Avatar
The solution:
The receiver must be set to one of the other "Sound Fields" than the default.
So take the remote control and click the + sign on the sound field buttons.
Then press it again to something like V MULTI or one of the many others.
The sound will then work.
This is for the sony receiver STR-ND1030 but it is also true for past generation receivers. I believe they must have two way sound communication capability though which is fairly recent (last 3 years).
Reply LCD Flat Panel Displays
