5.1 Surround sound system not working on Samsung ES 8000 TV - AVS Forum | Home Theater Discussions And Reviews
Old 08-14-2012, 12:46 PM - Thread Starter
Nicholas Zambas's Avatar
Hi i have a Samsung ES8000 Series 8 SMART TV, i have tried to connect my TV to a 5.1 surround sound system via a optical cable but i only get the front speakers working so not getting proper surround sound, if i connect the cable to the back of my SKY box i get full surround sound working fine so i know cable and 5.1 system is working fine, any ideas why it does not work when i plug into TV ? thanks in advance for any help
Nicholas Zambas is offline
Old 08-14-2012, 01:32 PM
robnix's Avatar
Quoted: 662 Post(s)
Liked: 494
Most TV's will only passthrough 2.1 over optical from external sources like STB's and Bluray players. Does your receiver have any HDMI ports and do any of them support Audio Return Channel?
Looky here!
robnix is offline
Old 08-15-2012, 06:41 AM - Thread Starter
It has a HDMI port as it has a DVD player for that port but not sure if this is Audio return,i dont think so as u have to select the DVD player so when u dont select it it is not active, i just want 5.1 surrond to come from TV rather the sattelite so when i turn off tv the sound turns as at the moment i turn TV off but sound is still on as it comes from SKY box
Old 08-15-2012, 07:08 AM
gregzoll's Avatar
Liked: 33
What are you watching, that you are only getting 2.1? If it is through an application such as Netflix, you will only get 2.1. Need to know more as to what the avrs is that you are using, so that others can be of better help.
gregzoll is offline
Old 08-15-2012, 09:47 AM
sitlet's Avatar
If your receiver only has one hdmi port, than it's an output and not an input. As stated above, about 95% of tv's will not passthrough 5.1 audio from an external hdmi source to the optical port. The optical port on the tv will only output 5.1 from the OTA tuner. Since your receiver does not have hdmi inputs, you will have to connect the optical cable to whatever source you want.
sitlet is offline
Old 08-15-2012, 11:31 AM - Thread Starter
Thanks for reply, if i understand you corectly i will have to conect the optical lead from my surround system to my SKY box to get 5.1 sound? as my TV will not output 5.1 surround sound?
Old 08-15-2012, 11:35 AM - Thread Starter
Thanks for reply , I just have a SKY box my TV and my LG DVD 5.1 surround sound system, when i connect my optical cable from my surround sound to my SKY box any programme with DD will come out as 5.1 surround sound, but, when i connect the same optical lead from my surround sound system to my TV instead of my SKY box when i watch a DD programme i do not get surround sound and just get 2.1 sound , hope this helps?
Old 08-15-2012, 04:44 PM
topr's Avatar
That's normal for the majority of displays.
topr is offline
