UPgrade from magnavox 15" HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 08-20-2012, 10:51 AM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
I'm looking for a quality reliable brand, like Samsung or LG, that makes TVs from the same manufacturer as Samsung, LG, Sony, etc, etc.
5.1 small-room size: 800 ft³+ 54 ft³ corner door space
AVR: Denon 1712
Fronts: Pioneer SP-BS41-LR /Center: Pioneer SP-C21 / Rear: Pioneer SP-BS21-LR
Subwoofer: SVS PC12-NSD
Screen: Samsung UN46EH6070 46" 1080p 3D LED 240 CMR TV
Viewing distance: 7.33 ft
Stealth3si is offline
post #2 of 16 Old 08-20-2012, 10:53 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Why not just buy a Samung, LG or Sony? They are worth it and aren't horrendously more expensive than the off brands.
Mik James is offline
post #3 of 16 Old 08-20-2012, 01:45 PM
TechFan84's Avatar
If you're looking to spend less but still want quality, I would recommend Vizio. But as the above poster said, I'm sure you can find a reasonable deal on an LG, Samsung, etc. if you look around.
TechFan84 is offline
post #4 of 16 Old 08-20-2012, 06:55 PM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Yeah vizio all the way if you do go with a bargian brand though the only 32' vizio i found wasn't very competitively priced so maybe they aren't budget anymore, stay away from brands like westinghouse, dynex, and insignia.
You pay more for a better quality picture though and i would say Sony provides the best picture in the low end with Samsung only falling to second due to their ridiculous obsession with dynamic dimming.
EDIT: After looking at prices, if you dish out for an lg or Philips you might as well move up to a Sony or Samsung for a jump in picture quality. Also Toshiba makes a better budget tv than Philips and Lg, usually at a cheaper price than the Samsung's and Sony's.
post #5 of 16 Old 08-20-2012, 11:14 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
My TV takes about 32 watts of power from teh wall.
so what's a reasonable upgrade of amount of power consumption should i consider? i.e., is 100 watts vs 250 watts reasonable for a energy-conscious consumer 5 hours a day,r elatively speaking?
AVR: Denon 1712
post #6 of 16 Old 08-26-2012, 08:38 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
Can i find a reasonable for Sony/Samsung in the $500-$600 dollar range that sport a 40" LED 1080p?
AVR: Denon 1712
post #7 of 16 Old 08-27-2012, 03:07 PM
TechFan84's Avatar
The Samsung UN40EH5300 would be a reasonable option for a $600 LED 1080p set. Its picture quality is above average, and it's fairly cheap on Amazon.
post #8 of 16 Old 08-27-2012, 07:59 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
Can i find a reasonable price for Sony/Samsung/LG/VIzio/Toshiba in the $500-$600 dollar range that sport a 40"+ LCD CCFL 120hz 1080p?
AVR: Denon 1712
post #9 of 16 Old 08-28-2012, 02:16 AM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
VIZIO
47" Class 1080p 120Hz LCD
AVR: Denon 1712
post #10 of 16 Old 08-28-2012, 09:22 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Sorry I haven't been following the post lately. I should have mentioned Vizio can be a bit of a mixed bag: http://reviews.cnet.com/1770-6475_7-0.html?query=vizio&searchtype=products&rpp=10&filter=500963=20611409|
post #11 of 16 Old 08-29-2012, 08:59 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
Is a VIZIO E472VL for $470 good?
Should I bite?
AVR: Denon 1712
post #12 of 16 Old 08-30-2012, 01:36 AM
Leon!'s Avatar
Liked: 35
Remind me again- which Samsung, LG, or Sony has Hannah Storm's head on the front of the box?
'Nuff said.
Leon! is offline
post #13 of 16 Old 08-30-2012, 06:06 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
$518.99 LG 42CS570 42-Inch 1080p 120Hz LCD HDTV
Any good?
Should I wait for it to go down to $420-$450?
AVR: Denon 1712
post #14 of 16 Old 08-31-2012, 10:03 AM
Leon!'s Avatar
Liked: 35
idk everything seems to keep dropping, but that 47" led-lcd, it looks like your best value.
Leon! is offline
post #15 of 16 Old 08-31-2012, 11:16 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
That vizio model is average with mediocre picture quality and a decent feature set.
Sony and Samsung are your best bet unless you want to stretch your budget to a 2012 vizio: http://m.cnet.com/reviews/vizio-m3d470kd/35159744
Lg's are relatively average compared to offerings from Samsung, Sony and Toshiba.
Lg's sometimes employ an ips panel for better viewing angles but they may only be available in higher end models, and even then it's a gamble.
post #16 of 16 Old 08-31-2012, 03:44 PM - Thread Starter
Stealth3si's Avatar
Quoted: 32 Post(s)
I'm thinking of buyign Samsung, but compared to buying a Vizio with an extended warranty, would it be unwise to buy a samsung/lg without purhcasing extended warranty?
anyway, here's a coupel of samsung on amazon that looks enticign but what's the diffrence between them that costs so much apart? They both seem similar i can't find it the differences can someone explain?
$547.99 Samsung UN40EH5000 40-Inch 1080p 120 CMR LED HDTV - Black
$618.83 Samsung UN40EH6000 40-Inch 1080p 120Hz LED HDTV (Black)
Originally Posted by RWilleyRN View Post
Also with any Samsung if you register online it extends your warranty by 12 months. Good Luck
I belive it's by 3 months. BUt generally speaking, if I buy a Samsung with AMEX card will my warranty extend for another year as well?
AVR: Denon 1712
Reply LCD Flat Panel Displays
Magnavox 15mf605t 15 Inch Lcd Flat Panel Tv , Lcd Hdtv , Samsung , Lg
