Samsung LNT5265F High Volume When Turning On - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-21-2012, 02:02 PM - Thread Starter
calphin's Avatar
My Samsung LNT5265F started have volume level at 85 when turning it on. Just started this since updating a Directv DVR. Tried setting volume down with TV remote to 5 or any low number. Let the tv set for 10 minutes or so and same thing. Volume goes to 85 when turning it on.
Any have an issue like this or have a suggestion?
calphin is offline
post #2 of 3 Old 08-21-2012, 02:21 PM
mes444's Avatar
Try a blu ray player or another box and see if the same thing happens. If it just happened with the new box, the problem seems to be the box. If so, it may be defective and the tv may be fine.
mes444 is offline
post #3 of 3 Old 08-22-2012, 11:54 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Are you using external receiver/speakers?
MrBobb is offline
Reply LCD Flat Panel Displays
