input lag LG 42LD550 LCD game mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-28-2012, 05:51 AM - Thread Starter
PBATEMAN999's Avatar
Good morning,
I need to know exactly the input lag LG 42LD550 LCD game mode and can not find it anywhere. I searched google and many pages but can not find.
I would appreciate if someone tells me they have this LCD Input Lag.
thanks
PBATEMAN999 is offline
post #2 of 3 Old 08-28-2012, 09:50 AM
walford's Avatar
The game lag is a function of:
1. The processing time of your PC and video card to convert your screen image to the resolution you are sending to your TV.
2. The processing time to convert the video resolution you are sending into the native resolution of the TV if any.
and 3 the processing time to time to process any TV video setting options that are still required in effect even when Game mode is in effect.
Therefore the lag of any TV model is not a constant.
g
walford is offline
post #3 of 3 Old 08-28-2012, 11:10 AM
John4721's Avatar
This fellow seems to have done some input lag testing for a 42ld550.
John4721 is offline
Reply LCD Flat Panel Displays
Lg 42ld550 42 Inch 1080p 120 Hz Lcd Hdtv With Internet Applications , Lcd Hdtv
