60"-65" LED, NON-3D TV. Under $1700 - Appears to be only 2 Options? - AVS Forum | Home Theater Discussions And Reviews
Old 09-01-2012, 09:15 PM - Thread Starter
CGHitman14's Avatar
Seems like these are the top picks. Am I missing anything?
Does Vizio have a 60-65" LED thats non 3D for cheaper?
$1350 - Samsung UN60EH6000 60-Inch 1080p 120Hz LED
$1200 - Sharp LC-60LE600U - AQUOS - 60" Class - LED - 1080p - 120Hz
Thoughts? Where do you go between these two? Any options that I missed?
CGHitman14 is offline
Old 09-02-2012, 09:34 AM
Steve S's Avatar
Liked: 46
Sharp's 640 series 60" often sells for 1399, has 4 HDMI vs 2 for the Samsung, Smart features with built-in WiFi vs none for Samsung.
Steve S.
Steve S is offline
Old 09-02-2012, 08:43 PM - Thread Starter
CGHitman14's Avatar
Primary concern is large size, good quality.
I can have all the HDMI put into one input if I just hook all my external components to a single receiver.
So again, large size, high quality image. Don't care about apps, 3D, HDMI, or anything else.
Just PRICE, PICTURE QUALITY, SIZE.
Old 09-05-2012, 08:47 PM
cj1319's Avatar
You might want to look at the LG 60LS5700. It's $1699 on Amazon now, but it was $1399 over Labor Day weekend.
cj1319 is offline
Old 09-05-2012, 08:51 PM
yaomizzle's Avatar
Liked: 26
If you want 2d PQ you should want a 3d TV. But if you don't want a 3d TV you don't care for PQ
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
Old 09-06-2012, 05:12 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
I don't know if one can generalize as such. There was a CNET review on Vizio TV that had a decent 3D performance but poor 2D picture. 3D capability doesn't necessarily translate into 2D quality.
Apostate is offline
Old 09-07-2012, 01:48 PM
tac
tac's Avatar
I've had the Sharp LC-60LE600U for a few days. The picture looks great to me, but I don't have any calibration equipment. The audio is not good at all, but if you're using a surround sound system 100% of the time that's not a concern. Unless you have the same issue that I have where the optical out doesn't work properly (see other post). I'm still trying to determine if it's a software bug or an issue with my TV, but I'm seriously considering exchanging it for the LC-60LE640U which is also currently under $1700 at all major retailers. The 640 model has smart TV features and built-in wifi, which I don't care about, but the 600 model has stripped down settings and seems to be a little too budget for my taste.
EDIT: Sharp said there is no fix for the issue with the optical audio output. So the built-in speakers are terrible and the only audio output doesn't work. Unless you plan to route all of your sources through a surround sound system, do not waste your time with the LC-60LE600U.
tac is offline
Old 09-08-2012, 11:46 AM
gordon7's Avatar
Sharp 60LE640U is a way to go. 600 is the value version, you'll get what you pay for. 60LE640U is $1399 pretty much everywhere
gordon7 is offline
