Image larger than screen - AVS Forum | Home Theater Discussions And Reviews
Old 09-02-2012, 04:31 PM - Thread Starter
jdr1000's Avatar
My tv image is larger than tv screen. Image goes from dish receiver to a hdmi splitter.
One tv is samsung another is a sony.
Any ideas? Already played with the zoom settimgs, image is hd.
J
jdr1000 is offline
Old 09-02-2012, 07:40 PM
walford's Avatar
What type of splitter do you have?
Is Overscan disabled on both TVs using the aspect ratio optionw?
What resolution are you sending the HD from your receiver to the splitter?
walford is offline
Old 09-02-2012, 10:13 PM
ChrisW6ATV's Avatar
Sometimes, you can only disable overscan by renaming the input you are using as a "PC" or "Computer" or similar. Try that and let us know if it worked.
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
Old 09-03-2012, 12:25 AM
Chronoptimist's Avatar
Liked: 532
Don’t know about the Samsung, but you should be able to disable overscan on the Sony by going to:
Settings → Display → Screen
Set Target Inputs to Common
Turn off Auto Display Area, and set Display Area to Full Pixel. (Changes to +1 with a lower than 1080i/p input)
Chronoptimist is offline
Old 09-03-2012, 01:42 AM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
The Dish receiver remote also has an aspect function. Did you hit it by mistake? Some have two, one is a key at the bottom of the remote and some also change aspect by hitting the page keys either up or down....
tampa8 is offline
Old 09-03-2012, 10:25 AM - Thread Starter
jdr1000's Avatar
I will try and re-check all those ideas and get back on this. Spliter is from Monoprice.
J
jdr1000 is offline
Old 09-12-2012, 05:00 PM - Thread Starter
jdr1000's Avatar
Stupid me, Sat receiver had a zoom applied. Found it by mistake. Thank you all for your help.
J
jdr1000 is offline
