Do some LED TV's do this? Flicker of tv logo on HD channels - AVS Forum | Home Theater Discussions And Reviews
Old 09-02-2012, 08:22 PM - Thread Starter
pcumming's Avatar
I have 2 Samsung UN46EH6000 LED tv's.
Automotion set to off.
I notice on certain HD channels (never non HD), that if there is text on bottom left or right bottom of screen, that text or logo will flicker.
Such text or logo may be the name of the show, next show coming up or the logo of the channel
Am watching Breaking Bad right bow and the AMC HD logo has a slight waver to it.
Notice this on on some other channels too but never on non hd.
Thanks for any input
pcumming is offline
Old 09-03-2012, 10:35 AM
Mik James's Avatar
Quoted: 105 Post(s)
Liked: 81
Lcd motion performance at work biggrin.gif I see it all the time on fine lines on lcds, motion improvement settings are there to mitigate it, if you have it turned of then you'll likely see it on alot of lcds.
Mik James is offline
Old 09-03-2012, 12:52 PM - Thread Starter
pcumming's Avatar
I made a mistake. Automotion was set to custom, i set it to off and the flicker of logo and text at bottom of screen went away
Pc
pcumming is offline
