Local dimming on LG 42LM6200? - AVS Forum | Home Theater Discussions And Reviews
Old 09-04-2012, 06:15 AM - Thread Starter
fishiepooh's Avatar
I have heard this set has local dimming but you need to "turn it on". My first quesiton is; is this true? If yes, why would it be turned off? I had thought local dimming was "better" than simply utilizing edge lit technology but perhaps I am not understanding the purpose of each. I've read a lot and that's what I took away from it but I must be incorrect. Any insight?
fishiepooh is offline
Old 09-04-2012, 09:01 AM
8mile13's Avatar
Quoted: 1484 Post(s)
Liked: 828
When Local Dimming is set to ON ''individual zones will be dimmed or brightened independently and because of this a Local Dimming can have significanty better black levels and uniformity than normal LCd''.
http://reviews.cnet.com/2795-6482_7-399.html
8mile13 is offline
Old 09-04-2012, 10:27 AM - Thread Starter
fishiepooh's Avatar
Right...I understand that and read that same review page (thanks for posting the link). But I am confused on this model specifically. My questions were really:
1. Does this set have local dimming or not (have seen conflicting reports)
2. If it does, why would it be a "turn on/turn off" function? Shouldn't it be on all the time?
Old 09-05-2012, 06:29 AM
8mile13's Avatar
Liked: 828
1.according to CNET its a Edge-LIt
http://reviews.cnet.com/flat-panel-tvs/lg-42lm6200/4505-6482_7-35153186.html
2. On will give you better PQ, if you do not like that you can turn it off. Lot of folks do not care about PQ.
8mile13 is offline
Old 09-05-2012, 07:02 AM - Thread Starter
fishiepooh's Avatar
I can understand PQ not being as important as other features. I don't feel that way but if others do, so be it. But if you had an option on a television to turn on to create better PQ, why on earth would you not do it? So then why wouldn't LG just remove it as an option and have it work all the time. Seems very odd to me. Looks like it's Edge lit with local dimming versus the more pure "full array".
Old 09-05-2012, 11:31 AM
barber76's Avatar
Maybe using local dimming will reduce LEDs lifetime? I mean, they'll be switched on/off quite frequently...
barber76 is offline
Old 09-05-2012, 12:03 PM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
Local dimming will not reduce LED lifetime, but rather prolong it. Local dimming also reduces the amount of energy consumption used by the television.
The reason why local dimming is an option, along with other PQ-enhancing options, is because NOT all sources would accommodate them.
For instance, gaming or fast action sources such as sports need extremely fast response times. By having PQ enhancing features turned on,
there will be a noticeable input lag as the processing required to analyse the source and enhance them does add additional milliseconds.
Milliseconds can add up and slow things down for gamers and the sort.
Therefore by turning off these features, you can eliminate a large portion of the input lag in the television.
Do-It-Yourself is offline
Old 09-05-2012, 01:01 PM - Thread Starter
fishiepooh's Avatar
TAHNKS DIY! Very enlightening!
Old 09-05-2012, 02:47 PM
8mile13's Avatar
Liked: 828
Seems to me that most Local Dimming owners use the Game Mode - automatically turnes Local Dimming off - when gaming and leave the Local Dimming option on (standard) the rest of the time. I myself use Local Dimming all the time even when playing games.
8mile13 is offline
Old 09-05-2012, 04:25 PM
fatuglyguy's Avatar
Quoted: 284 Post(s)
Liked: 614
The L,M6200 does not have local dimming. LG calls its edge-lit with local dimming tech "LED Plus." The 6200 does feature LED Plus. The feature begins at the LM6700.
Perhaps the local dimming option is baked into the firmware and is accessible through the 6200's service menu (some LG sets from 2011 were like this), but the 6200 does not officially support local dimming.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
Old 09-06-2012, 09:38 AM
gvc
gvc's Avatar
gvc is offline
Old 09-24-2012, 07:13 PM
Leonheart's Avatar
Quoted: 80 Post(s)
Liked: 24
Originally Posted by gvc View Post
http://www.avsforum.com/t/1403070/lg-passive-lm6200-dedicated-thread/450#post_22271637
local dimming can be activated in service menu
yeah but it doesnt look good IMO
55EG9100
PS4
Leonheart is offline
