Samsungs have gone downhill in quality, dont know if Id buy another - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-04-2012, 04:55 PM - Thread Starter
Princeismyname's Avatar
Quoted: 16 Post(s)
Samsungs arent the same quality they once were 3 or 4 years ago. I used to own 3 Samsung tvs (one from 2005, other from 2007 and 2009). The quality was amazing, no problems. But in the past 2 years, especially since they started pushing out razor thin LEDs with pratically no bezel, all the issues started coming up and fast. Ghosting, backlight bleed, clouding, this whole panel lottery they started in 2010 is just stupid and unacceptable business practice.
Princeismyname is offline
post #2 of 8 Old 09-04-2012, 05:25 PM
fatuglyguy's Avatar
Quoted: 330 Post(s)
Liked: 746
The panel lottery was going on before the 2010 model year. IMO Samsung has never been a brand known for their great reliability, rather great design and good picture quality (arguably, picture quality is in decline).
desktop + headphone Sonus faber Toy monitor|REL T Zero|Sony UDA-1|Sony MDR-Z7|Sony MDR-1000X|Audioquest NightHawk|Ultimate Ears Triple.fi 10|Sony NW-A35
ht Sony A1E 65" OLED|Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Sony UBP-X1000ES|Sonos Connect + Peachtree Audio DAC•iT|Panamax M-5100PM
stereo Sonus faber Toy tower|REL S/5|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony 43" X800D|Sony UBP-X800|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
post #3 of 8 Old 09-04-2012, 07:11 PM
frito's Avatar
these problems you mention have long been a problem with their panels, Sony TV's that had the same panels in them also had the flashlight and cloudy black picture issues.
the root of the problem is the type of LCD display it is that is the problem. xVA type panels have the LC's aligned in such a position that any amount of pressure on the display will cause them to "open" allowing more light to pass through. a good way to see this in action on your xVA screen is to put up a black screen and simply tap on it gently, xVA type LCD's will give off a large white halo of light around the area you tapped on them. go do the same thing to an IPS or TN panel (pc monitors are usually TN panels) and you will only see light appear where you press directly rather than all around that area of pressure. the reason for it is the alignment of the LC's are completely different than VA type panels
If you're a gamer or interested in using an LCD TV as a primary monitor take a look at my thread on Input Lag
frito is offline
post #4 of 8 Old 09-05-2012, 12:35 AM
esj
esj's Avatar
buy Panasonic
esj is offline
post #5 of 8 Old 09-05-2012, 09:42 AM
Steve S's Avatar
Liked: 46
Samsung got where they were by building the brightest set in the store. The flashlighting and clouding of current sets just doesn't show up in overlit showrooms with candy/neon bright source material.
Steve S.
Steve S is offline
post #6 of 8 Old 09-05-2012, 09:47 AM
frito's Avatar
The other thing that garnered them a lot of attention was their motion enhancers, back 3-4+ years ago theirs was one of the only ones that worked very well and was very adjustable.
frito is offline
post #7 of 8 Old 09-05-2012, 11:07 AM
Do-It-Yourself's Avatar
Location: In a house far away from you creeps (hopefully)
Liked: 24
They also fooled customers by giving store models with "S" panel (Samsung panels) while they did a switch-and-bait tactic by using cheaper and inferior panels in the same model.
So thinking you get the "nice" looking set at store.... well you get a different one at home.
PANEL LOTTERY!
Do-It-Yourself is offline
post #8 of 8 Old 09-05-2012, 11:56 AM
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
Unfortunately, I must agree...I have the A850 (2008 model, bought in 2009) and needed repairs.
I looked at the current avaliable models and none,
not LCD, LED-backlit, LED-edgelit or Plasma Samsung could match the old A850's killer picture.
I believe the Sharp patent lawsuit destroyed Samsung's advances in Picture Quality.
3D and Smart TV/Apps also took the focus off its once superior Picture Quality.
PiratesCove is offline
Reply LCD Flat Panel Displays
