Black Screen issues with UN37EH5000 - AVS Forum | Home Theater Discussions And Reviews
Old 09-05-2012, 12:10 PM - Thread Starter
DanHuff's Avatar
Just bought one of these since it is the only screen that would fit in my old "square" cabinet since it is only 34" wide.
When I am watching anything during scenes where the screen is mostly black it looks like there is a white "ghost" or reflection/"cloud"(?) of some king at the middle bottom part of the screen. If I move around and look at the tv from different angles the "ghost" or blob (as I like to call it) will disappear but when you look directly at the screen it is noticable during the black scenes.
Anyone now how to adjust the set so I don't see this during dark scenes? The pic is pretty nice in all other regards.
DanHuff is offline
Old 11-16-2013, 05:29 PM
Laurent Bovey's Avatar
Hi, just bought the same TV, and i have the same "ghost" problem...
Did you find something to do to reduce this effect? or it's a case of return to sender under warranty?
Laurent Bovey is offline
Samsung 37 Inch Led Hdtv Un37eh5000
