LG 42lk450 DTS codec issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 09-05-2012, 02:48 PM - Thread Starter
SSworks's Avatar
Good day,
i bought a LG 42lk450 and to my surprise it does not support DTS, i decided to convert DTS to AC3 (DD) using popcorn Audio converter but i realize that the audio isn't as crisp as the DTS and the channels arent as defined as with the DTS.
my Question is:
what codec can i use thats on par with dts that will work with my LG that will give me the same audio quality as DTS.
i use a WD live to play the DTS version, also the entire setup is going through a sony BDV-E300 HTS.
Thanks in advance
SS
SSworks is offline
post #2 of 23 Old 09-06-2012, 11:13 AM - Thread Starter
SSworks's Avatar
SSworks is offline
post #3 of 23 Old 09-06-2012, 12:28 PM
Killerbeenl's Avatar
LG does not have paid for DTS licence thats why its not supported
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #4 of 23 Old 09-06-2012, 12:29 PM - Thread Starter
SSworks's Avatar
yah i understand that and thats why i converted to ac3
SSworks is offline
post #5 of 23 Old 09-07-2012, 10:38 AM
Roger Dressler's Avatar
Quoted: 1858 Post(s)
Liked: 986
Originally Posted by SSworks View Post
Good day,
my Question is:
If you use a BDV-E300 for all the sound, why worry about feeding DTS to the TV? Send the WD's optical output direct to the BDV.
If that fails because the TV, being fed from the WD's HDMI output, tells the WD it cannot accept DTS, thus preventing the optical output from carrying the DTS, then now we understand the issue.
Might be a way to tell the WD to ignore the EDID of the TV. Or a way to block the EDID (such as Gefen HDMI Detective). Or, instead of an HTIB, upgrade to an AVR.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #6 of 23 Old 09-07-2012, 11:29 AM - Thread Starter
SSworks's Avatar
i thought of that but i wanted to get rid of the wdlive (its giving probs) that and one less thing to use a hdmi port but if i cant get the sound quality of dts from ac3 or another codec i guess i just have to do that
SSworks is offline
post #7 of 23 Old 09-07-2012, 12:16 PM
Liked: 986
If your source is DTS and the BDV-E300 plays DTS, what exactly is the problem?
post #8 of 23 Old 09-07-2012, 12:25 PM - Thread Starter
SSworks's Avatar
ok since i wasnt clear
the TV (LG 42lk450) to which the HARD DRIVE that contains the MKV file does NOT SUPPORT DTS which means if it is encoded with DTS the file WILL NOT PLAY!
THE SONY BDV-E300 has nothing to do with playing DTS or using the HDD.. it has nothing to do with my problem!!
all i am asking is what codec can i replace dts with that will give me the same quality because when i convert to AC3 (DD) the audio quality drops!
SSworks is offline
post #9 of 23 Old 09-07-2012, 01:13 PM - Thread Starter
SSworks's Avatar
case closed problem solved
SSworks is offline
post #10 of 23 Old 09-07-2012, 05:55 PM
Liked: 986
Well, you were the one that originally stated:
How can you tell the audio quality drops when you cannot even hear what the DTS version sounds like? >>DTS the file WILL NOT PLAY<<
Good news! So, how did you resolve the problem? Others may benefit from your experience.
post #11 of 23 Old 09-08-2012, 09:41 AM - Thread Starter
SSworks's Avatar
lets see if i can go even slower because i dont see where i am over complicating this
TV that you can play video from a hdd THAT DOES NOT SUPPORT DTS
WD live that plays video from a hdd THAT SUPPORTS DTS
HOME THEATER SYSTEM that all the audio goes to via optics from the tv.
SO LETS TRY THIS AGAIN
SSworks is offline
post #12 of 23 Old 09-08-2012, 09:46 AM - Thread Starter
SSworks's Avatar
when i use the HDD direct to PICTURE A i cant use DTS because PICTURE A does not support DTS so i have to convert to AC3 (DD)
when i use the HDD direct to PICTURE B i can use DTS because PICTURE B supports DTS and no conversion has to be done
EVERYTHING gets funneled to the PICTURE C via an audio fiber cable
when i compare the two the AUDIO QUALITY is not as sharp or crisp with the AC3 and in both cases my SONY BDV-E300 acknowledges that's its 5.1 srs.
SSworks is offline
post #13 of 23 Old 09-08-2012, 01:01 PM
Liked: 986
Correct.
Maybe. Maybe not. That's what we are here to discuss.
Picture B is the WD Live HDD, right? You must mean when use the HDD direct to Picture C (BDV-E300).
If HDD direct to BDV-E300 works with DTS, why not just leave it connected that way?
Maybe the AC3 converter is not of good quality. It would be best not to convert in any case, as cascading lossy codecs is never a good idea. The direct connection is best.
Hmm. SRS? You might want check the sound quality with the SRS turned off, just to confirm the AC3 source is still reported as 5.1. There are lots of SRS modes, so not sure if the one you have is upmixing from stereo to 5.1 or not.
post #14 of 23 Old 09-08-2012, 01:43 PM - Thread Starter
SSworks's Avatar
i see exactly where we are not on the same page simple fix
that WD live is not a hdd its a device that allows you to play video files from an external source (ext hdd or over the network) to your tv via hdmi (just one of the connections)
i have an external 500gb hdd that i connect to the WD live OR the tv not the bdve300.
i want to get rid of the WD live device because it is givin probs so for the reason of simplifying this convo lets say i didnt even have it
you need to remove the sony hts out of the equation because you can not connect a external hdd to it ...
now how do i convert DTS to AC3 to play on directly to my tv from my hdd AND KEEP THE AUDIO QUALITY!!
is there a better codec to use ?
SSworks is offline
post #15 of 23 Old 09-08-2012, 02:56 PM
Liked: 986
Thanks for the clarification.
now how do i convert DTS to AC3 to play on directly to my tv from my hdd AND KEEP THE AUDIO QUALITY!! is there a better codec to use ?
What bitrate are you using for AC3? If 448 kbps or lower, try 640 if offered. The TV might not like it since ATSC is limited to 448 kbps, but worth a try.
If that fails, could use stereo PCM. The TV can handle that, right? But then I suspect you will say that a stereo downix is not suitable because you want 5.1 audio to pass thru the TV into the BDV.
The TV is your limiting factor, not the HDD or the WD or the BDV. If you had a nice Blu-ray player, you would not connect it to the TV before the AV system (yes, you dodged that bullet with the BD player in the BDV). So if not the WD, you'll need some other device to pull the audio from the HDD to hand it over to the BDV.
post #16 of 23 Old 12-17-2012, 06:39 PM
badbuick's Avatar
Go into service menu and change country to Korea and it will play dts thru USB on TV with mkv files.
badbuick is offline
post #17 of 23 Old 12-17-2012, 06:57 PM - Thread Starter
SSworks's Avatar
can you give me a step by step guide to complete this task?
SSworks is offline
post #18 of 23 Old 12-18-2012, 05:03 AM
badbuick's Avatar
I have a harmony 300 remote and hit guide button and the TV will ask for a 4 digit pin and You put in 0413 and go to country region and change to KR from us and the TV will reboot and then ask what language hit English. Now I can play dts files via USB. Do a search on universal remotes for hacking service menu
badbuick is offline
post #19 of 23 Old 12-19-2012, 07:41 AM - Thread Starter
SSworks's Avatar
my remote is akb72915239
i found two methods nether of which worked,
they keep asking for me to menu button on the remote and on the tv but my tv has a HOME so out of common sense i tried the holding home on the remote and and o nthe tv and turning on the tv and nothing!
as simple as this sounds its becoming not so simple LOLOL
SSworks is offline
post #20 of 23 Old 12-19-2012, 08:13 PM
badbuick's Avatar
need to find a good universal remote with ez menu access
badbuick is offline
post #21 of 23 Old 12-19-2012, 08:22 PM
Otto Pylot's Avatar
Quoted: 1627 Post(s)
Liked: 1023
Accessing the SM for hacks is not always a good idea because it doesn't always work on all tv's, even within the same model line. One wrong push of a button or a lock-up and you'll brick your tv with no way to bring it back. There may be slight variations of main board builds that will prevent SM access for working from one tv to another. Be very careful.
Otto Pylot is offline
post #22 of 23 Old 12-21-2012, 06:30 AM
badbuick's Avatar
Good point. Then I would get an LG bp620 player and use USB thru that if You have a reciever
badbuick is offline
post #23 of 23 Old 01-21-2013, 12:01 PM - Thread Starter
SSworks's Avatar
problem with buying a second player is exactly that i have to purchase a second player
i already have this
SSworks is offline
Reply LCD Flat Panel Displays
