what are the proper ways or / things to clean LED screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-13-2012, 12:25 PM - Thread Starter
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
hello, my 3 year old son always left his thumb marks on my LED screen, and it is very hard to removed. any idea what kind of clothing i need to use? ty
caloyzki is offline
post #2 of 4 Old 09-13-2012, 07:39 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Kids can be destructive as can be the oils in your fingers. Usually a microfiber cloth is best and preferably without cleaners, just try moistening the cloth with water if necessary (I've seen recommendations for a light vinegar based solution) and don't rub hard, but depends somewhat if you have a glass outer or some sort of coating on the screen to contend with. What TV?
lovinthehd is offline
post #3 of 4 Old 09-13-2012, 07:47 PM
gregzoll's Avatar
Liked: 33
Grab an old t-shirt, or if you have some cloth diapers around, grab a clean one that has not be washed with fabric softener or dried with a fabric softener sheet. Then use distilled water with just a small drop of dish soap in it. If you go to monoprice.com, you can get the large bottles of LCD/Plasma screen cleaner cheap.
gregzoll is offline
post #4 of 4 Old 09-13-2012, 08:11 PM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
This question comes up every couple of months and you will get all sorts of replies. The safest way is to use a good quality, clean, microfiber cloth dampened with distilled water (warmed if necessary). For stubborn "peanut butter" smudges biggrin.gif some folks have had very good luck with a good eyeglass lens cleaner, again with a good quality microfiber cloth. Just press ever so gently and rub until gone. There are all kinds of commercial panel cleaners available but a lot of them have chemicals that can, and will, leave streaks at times. Water and a microfiber cloth is usually your best, and cheapest way to clean panels, especially if your panel has some sort of anti-reflective coating on it which can react with any number of compounds.
Otto Pylot is offline
Reply LCD Flat Panel Displays
