Sony XBR-HX950 Owners' Thread (XBR-55HX9​50 and XBR-65HX95​0) - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1441 of 4689 Old 11-06-2012, 09:16 AM
Flavius's Avatar
Liked: 46
Originally Posted by bekindrewind View Post
"They placed the Avengers disc in the ELITE and I was suprised that the picture motion was not fluid. If the term is juttering, then I will use that term. The movement was inferior to the smooth motion of the sony 65HX950. This concerned me as I expected the picture to be better on the ELITE. "
If you went into the Elite menu and tried some other motion settings, you can get the Elite to play it as smooth as the Sony did. Just as going into the Sony menu and changing some of it's many motion controls will affect it's smoothness.
I have done a direct comparison of the 70X5FD and 65HX929 (rebadged as a 65HX950) both running the same time out of my Anthem D2v and Oppo or Directv. Both sets were tweaked in movie mode, with cnet's settings. My findings were the Sony had better color accuracy and pop. The Elite had more consistent smooth motion when playing different dvd/blu-rays and Directv. The Sony I'd have to go into the menu and change some of the motion settings per the source I wanted to watch, more times then with the Elite. Some movies the Sony could not get the motion nailed (King Kong had some scenes where no mater what motion setting I tried, it could not find the right one), where the Elite always found a way to do it with some setting. The Elite has pulsing issues and some colors, (blues and greens) where not as accurate when compared to the Sony. I think the two very best LED sets out are the Elite and Sony. Sony, how about a 70HX950 for $8,500 vs Elites 70X5FD for $8,500. Five inches more really does help with immersion.
I'm a nutter when it comes to motion handling. I found the best setting on the Sony is MotionFlow Standard and Cinemotion Auto 1 for ALL content. They work in conjunction for all content, not just movies. Set it and forget it. This eliminates 90% of judder while preventing nasty Soap Opera Effect or motion artifacts in video games. It also is a LOT faster than the newest Samsung when motion settings are enabled. Would have been interesting if you could have done a lag test between the Elite and Sony with the smoothing settings on. But rest assured, as a motion interpolation junkie over here, I am very satisfied with the HX950 motion handling. I just wish it allowed motion smoothing in 3D games like it does in 3D movies.
Flavius is offline
post #1442 of 4689 Old 11-06-2012, 09:18 AM
Flavius's Avatar
Liked: 46
Originally Posted by nyorker27 View Post
Hey, I have the 55" and I went to the picture setting and set the display area to Full Pixel. However, Full Pixel will only stay at 1080i. Any resolution lower than that, the display area goes back to normal. Is that right? Shouldn't full pixel stay on for all HD resolutions (720p, 1080i, 1080P). Thanks for all your responses.
I found this too. It just remembers independent settings for each resolution. So you only have to set it once per resolution. There are a bunch of settings that are memorized independently per resolution, so watch out!
Flavius is offline
post #1443 of 4689 Old 11-07-2012, 01:27 AM
rogo's Avatar
Quoted: 1605 Post(s)
Liked: 1796
Originally Posted by guessqahumphrey View Post
I will be purchasing the 65" soon once there's enough gas in my car to bring it back home but cant seem to justify the extra 2k$ for only 10 more inches and the possibility of issues reported in the forum. I presently own a 55XBR8 and HW30AES 3D Projector with a 125" screen.7.gif
So you will buy the 65" or you won't?
I am confused.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #1444 of 4689 Old 11-07-2012, 02:05 AM
hoforearga's Avatar
I will be purchasing the 65" soon once there's enough gas sapa in my car to bring it back home but cant seem to justify the extra 2k$ for only 10 more inches and the possibility of issues reported in the forum. I presently own a 55XBR8 and HW30AES 3D Projector with a 125" screen halong.7.gif
Who cares if its improved over the HX929 in terms of zones, when you can't even buy the HX929 anymore, at least not in 65". This TV is not even near to being in the same price range as the Elite to begin with: $5500 for 65" vs $8000 for 70".
hoforearga is offline
post #1445 of 4689 Old 11-07-2012, 04:25 AM
Vincent Kompany's Avatar
Quoted: 268 Post(s)
Liked: 506
FFS people. street price for the 70" elite has been around $6k (and occasionally lower) for months.
Vincent Kompany is offline
post #1446 of 4689 Old 11-07-2012, 04:38 AM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
I am confused.
Must be a BIG car to fit a 65" in-a-box so I guess he needs a lotta gas, and if he lives in the Nor'east he'll have a bit of a wait in gas lines.lol laughter.gif
LG OLED 55B6P~Oppo UDP203~SonyXBR929~Denon 3311~Mirage V2 SPK-SYS w/ S10 SW~ DVP5000~Harmony1100
Optimum via SA8300-HDDVR
IMRIZZO is offline
post #1447 of 4689 Old 11-07-2012, 08:39 AM
Flavius's Avatar
Liked: 46
ONLY IF YOU WANT ZERO RETURN POLICY.
Flavius is offline
post #1448 of 4689 Old 11-07-2012, 09:04 AM
Quoted: 268 Post(s)
Liked: 506
post #1449 of 4689 Old 11-07-2012, 10:28 AM
JoelxD's Avatar
Quoted: 13 Post(s)
Liked: 25
Does anyone know if this TV can display how many hours are on the set ? And if so, how do I do it/see it ?
JoelxD is offline
post #1450 of 4689 Old 11-07-2012, 11:17 AM
BarrettF77's Avatar
Quoted: 61 Post(s)
Liked: 36
BB just had their delivery service attempt another replacement TV. This one was kind enough to have very bad lighting in the corners, two clumps of something under the glass visible at certain angles, and instead of a singular band in the middle, it had two. Glad to see Sony is stepping it up. Glad I told the delivery guys I was going to test it in the entry way before they even came in and unhooked the other one. I love how delivery guys sometimes are so impatient they can't be bothered with an extra 5 minutes. The time they saved in letting me hook it up kept them from having to install one TV and uninstall the other. Pretty silly. Sony is also dropping by today with one, so lets see how they do when it comes direct from the manufacturer. Do they cherry pick theirs?
BarrettF77 is offline
post #1451 of 4689 Old 11-07-2012, 11:52 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
I think it's time for you to move onto something else...
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #1452 of 4689 Old 11-07-2012, 11:57 AM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
No special selection, they just pull one from stock and ship it.
IMRIZZO is offline
post #1453 of 4689 Old 11-07-2012, 12:42 PM
BarrettF77's Avatar
Quoted: 61 Post(s)
Liked: 36
Second delivery today, this one from Sony handled by Ceva. Aside from the motor bike they stacked on the tv box, I'm hoping its good. Preliminary check seemed good. No pixels, minimal banding. A little dimmer in the corners than other, but otherwise seems good. Gonna hook it up in permanent location shortly. It's not impossible, but they seem hard to find with bb inventory.
And I can't move on as I made a deal with BB on taking two plasmas back because their staff made the mistake of selling me plasmas a year ago and said you couldn't get burn in. On IR if you break the plasma in correctly. Long story short, I can't switch tvs. And I honestly wouldn't want to given the alternatives. When you get a good set, this one is the best on the market. It's just frustrating the debris that gets behind the panels and having to endure what I have. Spending $10k on TV sets is a lot of money. What I'm expecting is nothing short of appropriate. But you may be ok with banding, dust under the glass and a stuck subpixel in the same set. My money tree is kinda barren as we save up for this stuff.
post #1454 of 4689 Old 11-07-2012, 02:07 PM
danjw1's Avatar
You can try going to Sony, though I know some had issues getting them to take care of issues with the HX929. So it may be a bit of hit or miss.
danjw1 is offline
post #1455 of 4689 Old 11-07-2012, 02:33 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
My suggestion is to go through "Sony Listens" on facebook, they are somewhat better resolving problems because they are aware of the "eyes" on them via facebook. I have directed several people there and they were responded to successfully. Good Luck .
IMRIZZO is offline
post #1456 of 4689 Old 11-07-2012, 03:01 PM
greenslime's Avatar
Just received my 65". I hate to say this but I feel like the 55" I just exchanged for this one had a panel that blows this one away. WS perfect with no banding. 65" came with dead pixels and vertical banding towards the middle of the display. Picture is much more dim and DSE.
This sucks.
greenslime is offline
post #1457 of 4689 Old 11-07-2012, 03:12 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Originally Posted by greenslime View Post
Just received my 65". I hate to say this but I feel like the 55" I just exchanged for this one had a panel that blows this one away. WS perfect with no banding. 65" came with dead pixels and vertical banding towards the middle of the display. Picture is much more dim and DDR.
This sucks.
My personal opinion is that the 65" sets needed more zones to effectively improve the image quality and most likely reduce the banding problems ....a lot of real estate with insufficient zones.
IMRIZZO is offline
post #1458 of 4689 Old 11-07-2012, 03:17 PM
greenslime's Avatar
thanks rizzo.
so bummed about this.
i wanted the quality that i experienced in the display of the 55, in the 65.
they are so different.
i hate to say it but the panel on the 65 sucks. is it possible there are different manufacturers for the 65 panel or all they all bad?
post #1459 of 4689 Old 11-07-2012, 03:24 PM
greenslime's Avatar
the 55 was so much brighter. why is that rizzo?
post #1460 of 4689 Old 11-07-2012, 03:39 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
the real estate of that panel is just to much to illuminate adequately and those panels were sub contracted by a few manufacturers and not under Sony's quality control. the 55" panels were better and the 46" panels were the best produced. ( I don't know why Sony dropped the 46" model from their line up ?)
IMRIZZO is offline
post #1461 of 4689 Old 11-07-2012, 03:43 PM
greenslime's Avatar
once again, thank you rizzo.
so you dont believe if i try to return for another one i might get the same panel from the 55? are they all this dim you believe.
want to save the hassle of having to play the panel lottery.
if they are all like this due to the screen real estate i wont be keeping the 65. the 55 was a very very nice display. very very bright!
post #1462 of 4689 Old 11-07-2012, 04:06 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Of most folks on the "exchange panel" merry-go-round only a few were satisfied sufficiently to finally keep their 65" displays, It's a real shame as these are truly great sets, quite competitive in PQ with the exception of the LED off axis problems. I would suggest you look to another 55" set.
IMRIZZO is offline
post #1463 of 4689 Old 11-07-2012, 04:56 PM
greenslime's Avatar
Strongly considering the 60" sharp elite.
Any advice?
(I'm in between the 60" sharp and the 55" sony xbr.)
post #1464 of 4689 Old 11-07-2012, 05:29 PM
bzal1122's Avatar
Any advice?
Neither. Too close to 2013. I personally am waiting to see what Sharp and Panasonic put out first. I almost jumped on the 950 but not enough improvement over the 929 and the bandig issue drove me away.
bzal1122 is offline
post #1465 of 4689 Old 11-07-2012, 05:31 PM
Hdfanboy444's Avatar
The 55" panel is the same one used in the 46" so what exactly makes the 46" panel better?
And may I suggest to greenslime that before you jump ship back to a 55" set if the whole issue is just brightness, make sure you have the 65" set up properly.
Go into preferences and make sure ambient sensor and light limiter (all the crap in there for that matter) is set off.
I can tell you I have a 65hx929 and I always leave backlight at 3 and its extremely bright. I can't bare to have it any higher especially in a fully darkened/dimly lit room. Don't see why it should be different for the hx950.
And wasn't it confirmed that the 65hx950 had 125 zones? That's about the same ratio to screen size as having 105 for the 55" and 96 for the 46" so I don't see why picture quality should be different.
I know 46/55 have SPVA vs SMVA for the 65 and most people would actually argue that the SMVA is superior to SPVA+Psa especially for 2d pq as the Psa tech sacrifices 2d performance (contrast+ viewing angles) in order to provide better 3d performance.
This would also explain the reports we got earlier about the 55" version having bad viewing angles whereas the 65 has been reported to be quite good for of axis viewing.
It also falls in place with flavius reporting somewhat poor 3d performance on the 65 whereas we are not seeing people say the same about the 55. Probably the Psa tech kicking in which is causing these differences. I'm not saying for sure, but just a guess base on the spec differences between these panels.
Hdfanboy444 is offline
post #1466 of 4689 Old 11-07-2012, 05:31 PM
greenslime's Avatar
I'm kind of stuck. I have 30 days to get a new tv.
post #1467 of 4689 Old 11-07-2012, 05:34 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Any advice?
This is quoted from David Katzmaier OF CNET from Robert Zohn's HD Shootout
The Elite wasn't perfect, however. Zohn cited a few color-related issues, including undersaturated green, an inability to reproduce accurate teal, and the fact that color calibration can't be performed while local dimming is engaged.
IMRIZZO is offline
post #1468 of 4689 Old 11-07-2012, 05:38 PM
greenslime's Avatar
Honestly, it's not just brightness. It feels like I got a cheap display.
I don't know if anyone has ever gotten the terrible dim displays instead of one of the good ones on an iPhone. That feeling like you just need to raise the brightness, but it's always maxed. The colors just seem washed out and soft as well. The 55 I just exchanged lit up my white room with bright lights and colors. This one doesn't do that at all.
post #1469 of 4689 Old 11-07-2012, 05:40 PM
greenslime's Avatar
And thank you Rizzo and everyone who has helped me with advice!
post #1470 of 4689 Old 11-07-2012, 05:41 PM
Reply LCD Flat Panel Displays
Sony Xbr 65hx950 65 Inch Bravia Led Hdtv , Sony Xbr 55hx950 Bravia Led Hdtv , Led Hdtv
