Getting a Used 46" HX 929 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-21-2012, 07:00 AM - Thread Starter
Richard p's Avatar
Hello and good day. I just found this forum a few days ago and I must say it is awesome. Well I need a new TV, but I can't go bigger than the 46" (I am replacing my KV-32XBR450 mfrom 2001!) I am looking at Craigs list and the 46" hx929 does pop up occasionally. My questions are: 1) What should I look out for when buying a used XBR? 2) What test should I preform to make sure all is well with the set? 3) What is the normal residual value (% off) on a high end used set? 4) If I can't find a 46" xbr, would the hx850 come close?
Thanks in advance for any input.
Richard p is offline
Reply LCD Flat Panel Displays
