Samsung LCD TV showing low battery warning pop-up? Do LCD TVs have battery? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-26-2012, 04:43 PM - Thread Starter
Pree's Avatar
My Samsung LCD TV showing low battery warning pop-up while changing channel or voice or anything with remote? Do LCD TVs have battery? The model code is LA32C450 and Software version is - T-MSXSDAAC-1003-2
And the vision of my TV is distorted since today morning. i.e. some dots are showing up on edges which makes the whole vision distorted. I checked up self-diagnostic picture test and those dots are showing up in that picture too. Till yesterday the vision was fine.
Pls tell me how to fix this? Also tell me that if really this LCD TV has battery and now that it is showing Low Battery warning pop-up, then will I need to get the battery replaced? If yes, then how much will it cost? Is it too expensive?
(Kindly ignore the grammer mistakes)
Pree is offline
post #2 of 2 Old 09-26-2012, 05:35 PM
Nujacc's Avatar
Quoted: 26 Post(s)
Liked: 30
Must be the Remote Control batteries
Nujacc is offline
Reply LCD Flat Panel Displays
