Green screen instead of original blue screen Samsung LCD TV - AVS Forum | Home Theater Discussions And Reviews
Old 10-02-2012, 03:07 PM - Thread Starter
raybest's Avatar
Screen color on Samsung 630 series TV monitor suddenly changed from green to blue. Explored avenues but no luck.
Suggestions?
Ray
raybest is offline
Old 10-02-2012, 03:23 PM
Ratman's Avatar
Quoted: 1291 Post(s)
Liked: 1032
Otherwise.... does the TV still work without issue? If so, why fret?
You could always try a firmware update to get "blue" back if it's a important.
And.... try unplugging the TV/monitor from wall power for a few minutes. Maybe a hard reset will resolve the issue.
Ratman is online now
Old 10-02-2012, 07:23 PM - Thread Starter
raybest's Avatar
TV picture is distorted - faces, eyes, etc. have green patches moving on them.
Ray
raybest is offline
Old 10-03-2012, 05:06 AM
Ratman's Avatar
Liked: 1032
Ah.... sounded like you only had a change of menu or splash screen color. redface.gif
Have you tried the power/reset and/or firmware update as suggested?
Old 10-03-2012, 02:25 PM - Thread Starter
raybest's Avatar
Went to Menu on the TV and tried different options with color, picture etc. Didn't solve the problem. could not find the Firmware location you mentioned. Have unplugged and plugged in all cables.
Ray
raybest is offline
