Considering a new TV and would appreciate some help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-02-2012, 06:32 PM - Thread Starter
MarcusarilliuS's Avatar
Hey guys,
I am in the process of considering upgrading to a new tv.
It will be to replace my KDL40W2000 bravia, which I use as my main PC monitor.
I will be using it for a mixture of watching tv series/movies and gaming.
I was considering a plasma as a friend of mine told me that the issues of IB and IR that used to plague plasmas have been solved, but after reading around different forums I find they are still present.
As it is my main PC monitor this just won't work.
So I decided to look at LCD/LED panels.
Some panels I was considering are..
http://www.amazon.co.uk/Panasonic-TX-L55ET5B-55-inch-Widescreen-Freeview/dp/B007RTY4HW/ref=cm_cr_pr_product_top
this..
http://www.alternate.de/html/product/Philips/55PFL6007K/1006329/?
and..
http://www.amazon.co.uk/Sony-KDL55HX853-55-inch-Widescreen-Television/dp/B007WZS7PQ/ref=sr_1_3?s=home-theater&ie=UTF8&qid=1349221788&sr=1-3
(It's active 3d but from what I can gather the crosstalk isn't noticeable?? Don't know how true that is though?)
My requirements are as follows....
*55-60 inch
*120hz+ refresh and as low a response time as is possible for gaming
*3D(from what I have read active leads to eyestrain and headaches after a while so was thinking passive, what would you guys recommend?)
(I also read that passive can provide zero crosstalk, is this true? As this is very important for me too as I have seen active 3d on a friends monitor and was not impressed with the crosstalk)
*Good contrast and blacks
*No light bleed/bloom or hotspots
Don't know if I can get a panel with all these specs, but if it's possible I'm sure someone here knows about it smile.gif
Just a bit bogged down at this stage from wading through reviews and reading contradicting opinions from different sources.
Looking forward to hearing some suggestions.
Cheers,
Mark.
MarcusarilliuS is offline
Reply LCD Flat Panel Displays
