32" TV on a budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2012, 10:30 PM - Thread Starter
betachi05's Avatar
I am looking for a 32" tv for under $400. I am not sure what to get because what I have determined to be the best does not fit my budget or size constraints. Plasma would be the first choice, but there are not any at 32" that I can find. Second would be a full array LED with local dimming, but that does not seem to be available in either my budget or my size range.
I am trying to decide if I should go with an IPS LCD from LG or maybe the EH series from Samsung with a "full array" and "global dimming"? Also, if there is something else that I should consider let me know.
Other details: Will be used for cable that can broadcast max 720p right now as well as PS3. I will not need 1080p because I will be sitting about 10-15 feet away, but if there is a deal I wouldn't shy away from it. Also I prefer the look of 60Hz panels as well.
betachi05 is offline
post #2 of 2 Old 10-06-2012, 10:33 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 565
Samsung UN32EH4000 or UN32EH5000
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Reply LCD Flat Panel Displays
