Vizio E601-A3 Owners Thread - Page 127 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 04-23-2014, 04:38 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Originally Posted by ComponentActual View Post
Can someone post the link to the CNET calibration settings? I have looked all over CNET and for the life of me can't find the dang settings. I know AVS often won't let you post a link so just put some spaces or something in there so that you can post it, I will figure it out. Thanks.
http://www.avsforum.com/t/1433329/vizio-e601-a3-owners-thread#post_22485899
shpitz is offline
Old 04-23-2014, 04:52 PM
ComponentActual's Avatar
Quoted: 29 Post(s)
I actually found that link but didn't think it was the settings everyone was referencing as it was a forum post. I assumed it would be on actual page over at CNET, thanks for the link. I think I am going to go ahead an order one of those WOW discs though. Though I am really struggling forking over $20 for something I will likely only use once, and probably won't even notice the difference of. Oh well gotta have faith.
ComponentActual is offline
Old 04-23-2014, 06:20 PM
Anon314's Avatar
You could always try the THX Tune-Up App first if you have the necessary devices/cables (e.g., iPhone/iPad + Apple TV or Apple HDMI conversion cable)
Anon314 is offline
Old 04-23-2014, 10:40 PM
EscapeVelocity's Avatar
Quoted: 530 Post(s)
Liked: 291
What's the long term prognosis for this set? Lot's of issues? failures?
Epson 8350 / Panasonic AX-200u / Optoma Graywolf 92" / Draper Luma 92"
Samsung 51F8500 / Panasonic P50ST60 / Vizio P502ui-B1 / Sony 50W700B LCD
Sony S790 / Panasonic BDT-220 / Roku 2 XS & Roku 2
Samsung F550 / Speakercraft CS3 / Yamaha YAS-105
EscapeVelocity is offline
Old 04-23-2014, 10:52 PM
largebody's Avatar
Well, it effects all inputs. Apparently this is a common problem with Edge lit TV's… angers me.
largebody is offline
Old 04-24-2014, 07:08 AM
chet1185's Avatar
Hello everyone. I am new here. Can I post an issue here or do I need to start a new thread? Thanks
chet1185 is offline
Old 04-24-2014, 07:11 AM
Super Moderator
markrubin's Avatar
Quoted: 1040 Post(s)
Liked: 2292
Welcome to AVS
feel free to post your issue here as long as it pertains to the thread title
Mark
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Old 04-24-2014, 07:34 AM
chet1185's Avatar
Awesome.
Well here we go.
First started a month ago. Came home from work, turned on the tv. We had a 3" black bar and a 3" white bar down the left side. All the way againt the edge. The screen was also white but you could see the image through it. The white screen eventually went away, and i could see the image where the black bar is and I could see through the white bar. Now i have the black bar and white bar constantly.
Technician came to "fix" it, he had a new motherboard and another small board. Neither of those fixed it. But when he did install everything and first turned it on, it was working great for 5 seconds. Then it just went back to the way it was. He put the old motherboard back in and that was that. I hope it can be fixed as i don't want to buy a different tv. I love this 1 but I would not buy it again.
Sent from my LG-LS860 using Tapatalk
chet1185 is offline
Old 04-24-2014, 07:35 AM
chet1185's Avatar
chet1185 is offline
Old 04-24-2014, 08:10 AM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
This happens in all inputs/hdmi ports?
shpitz is offline
Old 04-24-2014, 08:23 AM
chet1185's Avatar
Yes it does.
chet1185 is offline
Old 04-24-2014, 09:34 AM
Otto Pylot's Avatar
Quoted: 1368 Post(s)
Liked: 854
You can get the free AVS HD709 disk and not spend anything but time downloading it and burning it to a CD (must be played back on a blu-ray player though). Whatever disk you get you will use it more than once. Picture adjustments (even real calibrations) can shift over time so as long as you have a good disk, you can always make adjustments over time or periodically check your settings if you think something is off. Depending on how far off your tv is, and the adjustments available to you, you might see a noticeable improvement in pq. In that case, $20 is a good investment and you also learn how all of the various settings interact with each other.
Otto Pylot is offline
Old 04-24-2014, 09:50 AM
chet1185's Avatar
So, it could just need relcalibrated?
chet1185 is offline
Old 04-24-2014, 09:52 AM
crucial's Avatar
I think he is responding to someone that posted before you.
crucial is offline
Old 04-24-2014, 10:01 AM
chet1185's Avatar
Lol. My bad. Being new and posting in this huge thread could be confusing.
chet1185 is offline
Old 04-24-2014, 03:57 PM
Internet2's Avatar
I believe it was this link:
http://forums.cnet.com/7723-19410_102-574831/vizio-e601i-a3-picture-settings/
Internet2 is offline
Old 04-25-2014, 06:23 PM
chet1185's Avatar
Anyone have any ideas on my screen issue?
chet1185 is offline
Old 04-26-2014, 01:27 PM
FatnSlo's Avatar
I have the the E601i-A3E model. On the TV I have the HDMI ARC connected to my Yamaha RX-V375 Receiver's ARC HDMI port.
On the TV I have CEC Function Enabled and System Audio Control to On and the same with the receiver.
Up until this week whenever I would turn on the TV or turn off the TV it would turn on and off my receiver.
Then this week I got a notice about a new feature called SMART and I saw the firmware has been updated to 2.0.44.
But now, whenever I turn on the TV, it will no longer turn on my receiver. When turning off the TV though it will still turn off the receiver.
I contacted Vizio and they only suggested the power cycle procedure which has done nothing to fix this problem.
Anyone have a suggestion? I have not tried Reset TV Settings or Clear Memory yet. Should I?
Thanks for the help!
FatnSlo is offline
Old 04-27-2014, 04:36 PM
Internet2's Avatar
Its under warranty...have it replace by Vizio.
My TV I brought in November 2012 and still working great and still under a two year factory warranty ( special units get this).
I doubt anyone's factory warranty plus extended warranty expired yet..or did you buy this used?
Old 04-29-2014, 06:26 AM
jjdurrant's Avatar
Originally Posted by jjdurrant View Post
Wondering if you guys can help me out.. I have three HDMI devices hooked up:
Comcast
HTPC
Xbox
With the HTPC I get a random black screen (only when watching movies) but audio is fine.. usually the video returns on it's own.. Or I can immediately get video back by hitting the start button on my HTPC keyboard. I have tried other HDMI connections on the TV with same result which tells me it's somehow related to my HTPC. Anyone run into this issue?
I still have this issue.. and started noticing similar behavior with my cable box.. box flashes DU1 and signal is momentarily lost. No issues with Xbox One though.. very odd.
jjdurrant is offline
Old 04-29-2014, 07:15 AM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Do you also get picture back when you move the mouse or press a key? it sounds like the pc puts the display in power saving mode. Which software do you use to play media? Check in the options there to disable power management so that the computer doesn't enter any power saving mode during playback.
shpitz is offline
Old 04-30-2014, 09:02 AM
-KEK-'s Avatar
In case anybody is interested, Amazon has the Disney WOW calibration disk on sale today for $14.
EscapeVelocity likes this.
-KEK- is offline
Old 04-30-2014, 12:37 PM
Quoted: 29 Post(s)
Of course it goes on sale 2 days after I bought it.:mad:
Old 04-30-2014, 01:21 PM
Quoted: 530 Post(s)
Liked: 291
Old 05-04-2014, 02:15 AM
CurtisCee's Avatar
Originally Posted by primetimeguy View Post
Ya, everything is a trade off.  If you like a large bright screen lit up next to you while you watch a movie along with a 15-20ft HDMI tether attached to it then a laptop works.  :D
But if looking for a standalone device, the current state of today may require two boxes.  One that plays your movies/media off your home network, something like Popcorn Hour or Dune that can play anything you throw at it.  And two, a streaming device like Roku or Fire TV for your web content.
Go into your power settings: any laptop made within the last, oh say 20 years, will suspend the laptop screen after any amount of time you set...you can even change the setting so that nothing happens when you close your lid.
As for the cable, there's no need to hold a laptop anymore than hold an unnecessary Chromecast in your hand. So just as you set your extra device by your tv, I set my laptop next to mine, usually on the floor or on the table next to it. So it's a 1-foot cable usually, but sometimes I use a 2 foot or three foot cable because I just grab the first one laying around. I honestly no longer see the purpose of spending money on this additional devices for the "benefit" of getting less--when, counter to your points, you literally sacrifice nothing. The laptop is a huge improvement over these devices without any of the inconveniences.I see zero benefit or convenience of these extra devices over the laptop, and zero trade-off: laptop is the smarter choice.
CurtisCee is offline
Old 05-04-2014, 02:23 AM
CurtisCee's Avatar
Quote:There isn't any inconvenience. I have never needed to do anything other than press play and watch a movie, just I haven't needed a remote of any kind when sitting in a movie theater. We've really fallen for the marketing of these billion dollar companies. I can see the benefit of using a remote to flip from channel to channel in short-attention span bursts when watching cable television...but for movies...no, I'm not investing hundreds of dollars just so I can press play and then put the remote away, especially when I can do the same thing on the laptop--if I, for some strange reason, wanted to have the laptop right by me just so I could press play. I simply don't get it.
Originally Posted by shpitz View Post
Ya, everything is a trade off.  If you like a large bright screen lit up next to you while you watch a movie along with a 15-20ft HDMI tether attached to it then a laptop works.  biggrin.gif
[/quote]
It's all about convenience (a remote vs kbd/mouse), power consumption (~1-5W vs ~130W+, idle is <1W vs ~50W, and these are mostly idle during the day), and noise (completely passive vs fan noise).
Old 05-06-2014, 12:05 PM
gr1vlet's Avatar
Question:
I have one of these on the way from tiger (they currently have a good deal on a refurb with the mail-in rebate) and I want to start working on getting my setup put together. I was wondering if someone could measure from the bottom of the tv (not to the bottom of the stand) to the top VESA mount hole for me and give me a measurement in inches to the nearest 1/4"
This is for the purpose of mounting my center speaker in the correct location.
I appreciate it!
gr1vlet is offline
Old 05-06-2014, 03:52 PM
largebody's Avatar
So Im having trouble with some of the TV screen uniformity issues (Posted some pictures earlier) after 4 weeks, hours on the phone with vizio, and them sending out a repair team, Vizio refuses to do anything about my screen. The HD repair team they sent out acknowledged  it was a defected panel, however they told Vizio that it was fine. Long story short, the people at Vizio are a bunch of snakes. So now Im stuck with a TV with a defective panel. Runs me real hot.
Old 05-06-2014, 04:25 PM
gr1vlet's Avatar
Can I has measurement?
Sent from my LG-E980 using Tapatalk
gr1vlet is offline
Old 05-07-2014, 01:16 PM
crucial's Avatar
I don't know if I can get enough access but I'll try measuring my set tonight after work
crucial is offline
Vizio E601i A3 60 Inch Led Lcd Hdtv , Led Hdtv , Samsung Un65es8000 Led Hdtv , Samsung Un46d6400 Led Hdtv
