My LN40A750 will not start up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-10-2012, 01:26 PM - Thread Starter
hcan's Avatar
The leds turn on one by one as normal, but the screen is black and the sound is off, then it turns itself off after about 10 sec.
Is there a way to factory reset the tv without entering the service menu? Or can I reset the eeprom in some way?
hcan is offline
post #2 of 4 Old 10-10-2012, 03:47 PM
EG3
EG3's Avatar
Samsung is offering a one time free of charge fix for this issue on some models. Blown capacitors in the power supply were common for that model. Call them, if they wont fix it, it is a relatively simple repair that you may be able to do yourself.
EG3 is offline
post #3 of 4 Old 10-10-2012, 04:05 PM - Thread Starter
hcan's Avatar
Thanks, I will call them.
Do you by any chance know where the eeprom is placed at the main board? Might try that as an option, since the capacitors looks fine.
hcan is offline
post #4 of 4 Old 10-11-2012, 02:07 PM
EG3
EG3's Avatar
I have no idea about the EEPROM. I don't do much tinkering with the Main PCB unless I find a faulty regulator. Other than that, I generally just replace the entire board.
EG3 is offline
Reply LCD Flat Panel Displays
Samsung 40 Inch Lcd Hdtv Ln40a750
