Sharp LC-60LE600U Help. Picture is too dark, won't get brighter. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-15-2012, 04:50 PM - Thread Starter
campingcam's Avatar
I went and bought the 60 inch Sharp LED (LC-60LE600U) from best buy about a week ago and im having this issue with it. I originally bought a LCD tv from best buy but I was not to happy with the picture so I returned it for the LED I have now. My problem is that the picture is too dark and changing the brightness to a higher setting does nothing but give everything a grey look. I originally noticed this while playing Resident Evil 6 (a fairly dark game). I had no problems on the LCD in terms of brightness with the same game. (The reason I returned it was motion blur) Playing on the LED I can barely see anything. I bought a calibration disk of amazon (the Disney one) and tried calibrating the brightness with that but its the same problem. Even at max brightness I still can't see the squares that I should be seeing at normal brightness while calibrating. So whats going on? Is there a hidden darkness setting that I don't know about? I have the OPC turned off and its on USER settings so im not sure what im doing wrong. Any help would be greatly appreciated.
campingcam is offline
post #2 of 4 Old 10-16-2012, 02:48 AM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
Use the Contrast setting to increase brightness.
johnfull is offline
post #3 of 4 Old 12-27-2012, 08:04 AM
noon0's Avatar
I have the contrast set to max (40). Still no luck. The darks are way too dark, the whites are too bright. Horrible set, but you actually get what you pay for.
noon0 is offline
post #4 of 4 Old 12-27-2012, 09:08 AM
RiverSide's Avatar
Quoted: 59 Post(s)
Liked: 37
what about Backlight? Should be able to get an extremely bright and reasonably acceptable picture with any LED-lit TV set to 50% backlight, 90% contrast and 55% brightness.. Unless the set severely crushes black., almost all current LED-lit models do to some extent to copy plasma blacks.. And fail miserably at that..
Insert pithy comment here
RiverSide is offline
Reply LCD Flat Panel Displays
Sharp Lc60le600u Led Hdtv
