How to play mkv file on Sony Bravia LED tv-a guide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-20-2012, 04:16 PM - Thread Starter
lake1988's Avatar
I am noticing that people are complaining about bravia led not playing mkv files. So here is a guide on how to play them.
1.Download tsmuxer GUI..it's a freeware.
2.Add the mkv file u want to play.
3.if u select the video track there is an option change level..if it is greater than 4.1 change it to 4.1.
4.now in output select m2ts muxing and point the output to a destination folder and click on start muxing.
You can playback the output file from your usb drive on bravia.
It can playback AC3,AAC,MP3 as embedded audio in m2ts.
It will take about 2 min if u are muxing 2 gb file..and so on.
Bravia can read exFAT, FAT32,FAT16(file size support 4 gb, disc size support 32 gb).
Pls post if you are having any problem with playback.
mkv is a container and m2ts is also a container. This application only change the container.. doesn't reencode the video..so there is no huge cpu requirement.
Pishang Ujeniya likes this.
lake1988 is offline
post #2 of 6 Old 10-26-2012, 04:50 PM
demoetc50's Avatar
I picked up a Sony KDL55EX645 today. After installation I took a USB thumb drive, formatted it FAT and loaded mkv, avi, jpeg and mp3 files from my Mac.
I attached the USB drive to a USB port on the EX645 then using the remote chose HOME>Media , selected the USB drive and then Photo, Music or Video depending on the file type I wanted to play, then the appropriate file. They all played perfectly. No need to convert.
Edit: There seems to be a file size limitation with FAT formatted drives. exFAT or FAT32 is a better option.
Also, mkv files play very nicely if I stream them to the TV through a PS3 using PS3medialserver. This option has the added benefit of being able to handle dts audio,
demoetc50 is offline
post #3 of 6 Old 12-10-2012, 08:19 AM
Ivan Sivakumar's Avatar
Hi lake..i just converted by using tsmuxer GUI as per ur guide lines.. but i cant hear audio only video is feasible in my sony led EX 650 not able to hear audio....pls help...
Ivan Sivakumar is offline
post #4 of 6 Old 07-21-2013, 09:40 PM
Pishang Ujeniya's Avatar
Thanks lake1988
I done as you said And now i am able to play mkv file video but the sound doent come In the file what the problem would be please reply...
Pishang Ujeniya is offline
post #5 of 6 Old 07-21-2013, 09:42 PM
I done but not able to play sound along with video...
Thanks Atleast i am able to play video But It would be better if it should play audio tooo
post #6 of 6 Old 08-02-2013, 07:37 AM
Vipul Garg's Avatar
After converting, file is working perfectly but subtitles are not showing in the video. Plz help
Vipul Garg is offline
Reply LCD Flat Panel Displays
