TV stuck updating firmware - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-01-2012, 02:37 PM - Thread Starter
8traxrule's Avatar
My Sharp LC-60C7450U started updating its firmware more than 90 minutes ago and has been stuck for over an hour at 67% as shown here. I called Sharp's tech support and they said someone will have to call back later. Anyone had this happen before? I won't unplug it since it says not to, but not sure if anything else will make it snap out of it.
8traxrule is offline
post #2 of 6 Old 11-01-2012, 02:45 PM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
Yikes! Is that a new update? There was one in October that installed correctly. We should all refuse it if it's a killer!
johnfull is offline
post #3 of 6 Old 11-01-2012, 03:42 PM
johnfull's Avatar
Quoted: 367 Post(s)
Liked: 109
My LC-70LE845U updated without incident.
There are others with problems, though, and a secondhand message from Sharp that the update might be corrupted.
I'll have to see if anything untoward occurs as a result. I had the random re-boot a couple of times back in August after an update.
The unplugging for 5 minutes fixed it -- I think I was the first to post that remedy...
johnfull is offline
post #4 of 6 Old 11-05-2012, 12:05 PM - Thread Starter
8traxrule's Avatar
I got a call back from Sharp who told me to unplug it anyways. That got the TV working again but I now cannot access Netflix or any other "smart" features until it successfully installs the update. It prompts me to do it over the network again, but still freezes at 67% requiring unplugging the power. I downloaded the new firmware to a USB drive and updated it that way- the TV first said that was "successful" but then says there was a "software update failure" when trying to access Netflix, and again prompts you to do a network update.
post #5 of 6 Old 11-11-2012, 10:18 PM
policy's Avatar
Did you ever get this fixed? Same issue here.
When an episode of Walker Texas Ranger was aired in France, the French surrendered to Chuck Norris just to be on the safe side.
XBL:MileHighMurder
PSN:SayH1ToYourMom
policy is offline
post #6 of 6 Old 11-12-2012, 04:07 PM - Thread Starter
8traxrule's Avatar
Nope- just tried updating again today and still gets stuck. While it's updating there's a bar on the screen that flashes and gets progressively bigger as it goes through the process. At 67%, it eventually stops flashing and that's where it locks up.
Reply LCD Flat Panel Displays
